Just installed Audirvana update 3.5.33. Audirvana preference is set for Playback Designs MPD3 and IMAC recognizes it but playback defaults to internal speakers, not my system. Reset optimizer but to no effect. Problem does not exist with Tidal or Idagio apps. How do I fix this? Following is debug info:
Audirvana Mac Version 3.5.33 (3563)
macOS 10.13.6 with 4096MB RAM
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Fri Jan 17 15:29:36 2020
Library database path: /Users/johndigangi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Max. memory for audio buffers: 1664MB
VI DAC Infinity 2V1
Model UID:VI DAC Infinity 2V1:2522:0012
UID:AppleUSBAudioEngine:LH Labs:VI DAC Infinity 2V1:fa130000:1
Active Sample Rate: 96kHz
ID 0x42 MPD-3 Manufacturer:Playback Designs
Model UID:MPD-3:23BA:0003 UID:AppleUSBAudioEngine:Playback Designs:MPD-3:fa140000:1
Stream ID 0x43 2 channels starting at 1
16 virtual formats:
16 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:24 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x42 MPD-3 Manufacturer: Playback Designs Model UID: MPD-3:23BA:0003 UID: AppleUSBAudioEngine:Playback Designs:MPD-3:fa140000:1
