Sync list: 0 folders
Library database path: /Users/gwilhermdevallan/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15360MB
FOCAL ARCHE Audio 2.0
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0
UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14400000:1
Hog Mode is on
ID 0x62 FOCAL ARCHE Audio 2.0 Manufacturer:FOCAL
Model UID:FOCAL ARCHE Audio 2.0:152A:87A0 UID:AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14400000:1
Stream ID 0x63 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Device #0: ID 0x62 FOCAL ARCHE Audio 2.0 Manufacturer: FOCAL Model UID: FOCAL ARCHE Audio 2.0:152A:87A0 UID: AppleUSBAudioEngine:FOCAL:FOCAL ARCHE Audio 2.0:14400000:1
Device #1: ID 0x4d Haut-parleurs MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
