Can’t load songs or move to the next one.
No Issue with Qobuz app. I can’t play files from external HD as well. Loading not effective.
Can you dump the debug info here?
In Audirvana try disconnecting from Qobuz and then reconnecting again.
Audirvana Studio 3.5.51 (2051)
Windows 10 (19044) with 16GB physical RAM
SoX to DSD512 with filter type B 7th order
Anti-aliasing = 97.4717
AUTO: E:\backup-003836
Library database path: C:\Users\jeanf\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 4982MB
Local Audio Engine:ASIO 2 driver version 2
T+A PDP3000 USB ASIO
Model UID:T+A PDP3000 USB ASIO
Device: 2ch 8bits Integer, 2 bytes per frame 22579.2kHz
Active Sample Rate: 22579.2kHz
T+A PDP3000 USB ASIO Manufacturer:
Model UID:T+A PDP3000 USB ASIO UID:T+A PDP3000 USB ASIO
13 available sample rates up to 45158400Hz
5644800
11289600
22579200
45158400
DSD capability: Raw DSD (MSB)
2 ch DSD 8bit big endian in 8bit chunk 45158.4kHz
Device #0: T+A PDP3000 USB ASIO Manufacturer: Model UID: T+A PDP3000 USB ASIO UID: T+A PDP3000 USB ASIO
Device #1: TEAC ASIO USB DRIVER Manufacturer: Model UID: TEAC ASIO USB DRIVER UID: TEAC ASIO USB DRIVER
Reconnected Qobuz, same problem. I can play a song from external HD after waiting for a few mns to load, then next one does not follow.
Disable upsampling and try again.
