Innuos zen 3 and audirvana
can i connect my innuos zen 3 to audirvana to stream tidal?
I really dont like the sound of roon
No, but you can connect your DAC to a computer running Audirvana. You can use the Zen as server where the files are stored.
I’m wanting to stream tidal so your saying without a seperate computer it cant be done. thanks
You can stream Tidal directly on the Innuos devices, just not through Audirvana.
You can, using Audirvana to stream TIDAL and send music to the Innuos via DLNA/UPnP.
I don’t think this is true. At least, I don’t see the Innuos showing up at a DLNA/UPnP player in the Audirvana app at all.
