iOS Sequoia 15.5
My iFi Zen DAC v2 stop playing in my Mini Mac M2 after the last actualisation of the OS. I use Audirvana Studio, connected to a Marantz SR 8012. I made the same conection with and old windows laptop and works perfectly fine. I suppose that I must wait some Mac OS solution or Audirvana correction. But have anybody the same issue? Thanks.
More information is needed…
Please paste your debug information here so we can see your computer platform configuration and your Audirvāna configurations in concert with your DAC.
Audirvana Studio 2.11.0 (21100)
macOS Versión 15.5 (Compilación 24F74) ARM64 with 8GB physical RAM
Connected account of : Julio Argentino Roca
Local network access: allowed
	Per track: OFF
DSP NOT ACTIVE
Bandwidth at 0dB = 90.2776%
Filter max length = 23929
Anti-aliasing = 95.1861
Phase = 75%
Sync list: 0 folders
Sync folders at startup: YES
Sort and display order: es
Library database path: /Users/julioroca/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 4563
Listening on on port 49262
TIDAL: Connected as PREMIUM
Font size: large
Language: Idioma del sistema
Streaming
Mi música
Señales de radio
Podcasts
Locales
Startup view: Mis listas de reproducción
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: yes
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
iFi (by AMR) iFi (by AMR) HD USB Audio
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0003:1
Selected device:iFi (by AMR) HD USB Audio
Manufacturer: iFi (by AMR)
Model name: iFi (by AMR) HD USB Audio
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0003:1
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
ID 0x4f
MQA Decoder device
Stream ID 0x50 2 channels starting at 1
32 virtual formats:
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
Local devices found : 3
Device #0: ID 0x59 marantz-AVR
Manufacturer: MJI
Model UID: 35494100-0000-0000-001B-010380794478
Model name: MJI marantz-AVR
Device #1: ID 0x4f iFi (by AMR) HD USB Audio
Device #2: ID 0x49 Altavoces del Mac mini
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Altavoces del Mac mini
Wi-Fi
UPnP devices found : 2
Device #0: ID 0x0 : Marantz SR8012
UID: uuid:87afabe5-dcd8-1da8-0080-0005cdc17702
Location: http://192.168.86.121:60006/upnp/desc/aios_device/aios_device.xml
Manufacturer: Marantz
Model name: Marantz SR8012
Device #1: ID 0x0 : Smart TV Pro
UID: uuid:bf3e3ffd-7d66-4d75-abb8-b7ec6bfabeff
Manufacturer: Microsoft Corporation
Model name: Windows Media Player
Chromecast devices found : 2
Device #0: TV de la sala de estar
Model name: FlowBox-F1
Device #1: Smart TV Pro
Model name: Smart TV Pro
Have you reset your playback system?
Try turn off the DAC and then power-down your computer… Reboot your computer … wait for it to boot… power the DAC… open Audirvāna…
Make sure you are setting the Marantz to receive signals from the DAC and not the Ethernet interface.
*Also, something is not right with the DAC sample rate support… it is not showing DSD capability when it supports up to DSD256.
Today I start reading and searching in the manual off al the parts of the system. Finally I found an option in the cellphone remote
Of the Marantz that don’t exist in the standard remote and menu in the TV, and I found the possibility of decide a way to force the analog output only. and then voilà. Al start normal again. Is a software problem. In the past the system change automatically between multichannel or analog when the source are multi channel o stereo only. Nothing perfect but it works. Is the first time I found that options in the cellphone remote. Thanks for your help and time. Either way, I’ll try to get the old automation back. I’ll try with Marantz. Thanks again.
