Hi,
Each 16bit/44kHz I listen to with Tidal is sent out as 24bit/44kHz even if I have upsampling etc. disabled.
I have this problem both with Audirvana 3.2 and the newest 3.5.
Why?
Thanks,
Alberto
Hi,
Why?
Thanks,
Alberto
Sorry, it’s not just with Tidal.
Just tried with an APE file 16/44kHz: it goes out as 24/44kHz
attaching debug info:
Audirvana Mac Version 3.5.15 (3545)
macOS 10.13.6 with 8192MB RAM
Registered to Alberto Dainotti
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 1011167
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
AUTO: /Volumes/PublicMediaShared/music/Acoustic Sounds Super HiRez
Library database path: /Users/alberto/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Cambridge Audio USB 2.0 Audio Out
Model UID:Cambridge Audio USB Audio 2.0:22E8:851D
UID:AppleUSBAudioEngine:Cambridge Audio :Cambridge Audio USB Audio 2.0:0000:1
Device: 2ch Non-mixable linear PCM Interleaved 24bits little endian Signed Integer, 8 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
ID 0x33 Cambridge Audio USB 2.0 Audio Out Manufacturer:Cambridge Audio
Model UID:Cambridge Audio USB Audio 2.0:22E8:851D UID:AppleUSBAudioEngine:Cambridge Audio :Cambridge Audio USB Audio 2.0:0000:1
Stream ID 0x34 2 channels starting at 1
12 virtual formats:
12 physical formats
Local devices found : 3
Device #0: ID 0x28 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x2f HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{6D1E-0001-01010101}
Device #2: ID 0x33 Cambridge Audio USB 2.0 Audio Out Manufacturer: Cambridge Audio Model UID: Cambridge Audio USB Audio 2.0:22E8:851D UID: AppleUSBAudioEngine:Cambridge Audio :Cambridge Audio USB Audio 2.0:0000:1
UPnP devices found : 1
Device #0: ID 0x0 [LG] webOS TV OLED65B7A UID: uuid:c3336a99-a54b-9250-f7be-177fc2d054c1 Location: http://192.168.69.43:2038/
Hi Alberto1!
I observed the same behaviour with every USB-device. Only when streaming via UPnP/DLNA you get a choice to adapt max bitrate manually.
So this works as designed it seems to me.
But I guess you’d join me in the wish to have this functionality also in USB?
BR
BB
Hi BeagleBoy, thanks for responding!
I don’t want to adapt max bitrate manually, I’d like simply the bit stream to remain untouched by Audirvana and sent to the DAC as is.(If it’s 16 bit should be sent as 16 bit, if it’s 24bit then it should be sent as 24.)
What am I missing?
Thanks,
Alberto
Hi Alberto1!
But this seems the way to do it. I just found out there is a difference between WASAPI and ASIO. I’m in Windows, you are MAC, right?
In WASAPI there is a switch to limit bitrate, but it’s not necessary because this way bitrate is transferred correctly. Strange enough…
In ASIO bitrate is always max of device, and can be wrong as with my Cambridge Audio DAC magic plus. It is 24 bit, Audirvana says it is sending 32. But it works:flushed:
You seem to have that switch: Limit bitdepth to 24bit: OFF
If your device is 24bit, it might help?
BR
BB
It looks like a bug to me. Most likely it’s just showing a wrong value and not up-converting.
When the music is not playing it shows the maximum capability of my DAC. Once the music starts, it shows the correct sample rate but the bit depth shown is always 24 (with limit bit-depth set to ON).
BTW, it’s not limited to Tidal. Happens also with the local/NAS library.
Yeah bitracer, it happens with everything. How do we get the attention of the developer?
Thanks,
Alberto
Have the same issue with the bit rate. No matter what I am playing the bit rate send out is the Dac’s maximum. I don’t know why is that and how to make sure that when a file is played which has a 16 bits sample rate then 16 bits are send out.
Got a new ADI-2 DAC used with W10 USB. Not possible to use it with Audirvana since the bitrate get changed. Distorted sound. Any work around?
Check if upsampling is enabled.
It is deactivated. I have tried every setting available in Audirvana both in WASAPI and ASIO but same problem. Distorted sound due to wrong samling rate. With the Windows Groove app it is OK.
Interesting, when playing FLACs at 16/44.1 it also shows 24/44.1 on my system. I don’t notice any sound degradation though. I always discarded the 24bit playback display as a presentation bug. Maybe Audirvana is just padding the value with zeros from 16 to 24bit.
Still, I’m just guessing. It would be nice if @Antoine could shed some light on this.
i think it just shows what your dac is able to deliver… when playing a 16/44 file, mine shows 32/44, playing a 24/44 file it shows 32/44 also…
i’m on a mac…
I seems like it is only the FLAC tracks which are 24 bits that are effected. Audirvana transferes the 24 bits to 32 bits and the sound is distorted.
I also have 24 bit FLAC files, but I don’t have this problem. Probably because my DAC doesn’t support 32 bit playback.
You can limit the bit depth to 24 bit in the settings.
Not when going out via USB…
BR
BB
After more testing I found out that the DAC is not the problem. I have the same problem when I stream from my NAS to my Denon AVR-X7200WA with built in DAC. It must be something with Audirvana software and my 24 bits FLAC files. Can you recommend an other software with the same features? Have used Groove but I do not like the sound.
Hi aja!
There are others, roon, amarra, foobar and more. But no recommendation from me for one of those. To your Denon you could play via Upnp, with WiFi. Then out via S/PDIF or TOSLINK to your DAC? Sorry, no better idea at hand.
BR
BB
I have tested both WASAPI and ASIO the problem with distorted sound on some files persist. I can manually fix the problem by setting the sample rate in the driver, but then other files get distorted. I have now tested the Amarra Lux software from Sonic Studio and the problem is gone.
Thank you for helping.
