Issue logging to HRA
Cannot login anymore to HIGHRESAUDIO streaming “Error logging to HRA-Streaming”
Hi @Mahatma63,
We are sorry about this situation. HRA is currently dealing with this issue, which is affecting the API we use to connect to their servers.
I know they are moving to a cloud infrastructure, maybe this is the cause…
Hi @Antoine . The logging issue seems to be solved, but now there is a further problem: the “explore” sub-menu is empty:
Is it stil a HRA issue or a Studio issue ?
Thank you
API related if you look at the logs. I will look at this as soon as possible. The other sections seems to work.
Everything is fine now, thanks @Antoine :pray:
