Issues with 2.0 - Blocked from TIDAL log in
So I have Qobuz and Tidal. I was logged out of tidal when the update happened. I went to log in again after the update and it wont let me log in. It keeps taking me to the sign up page. First it takes me to the sign in or sign up page. I then input my info, and it takes me to the sign up page. My tidal account is active, and I use it on my phone. I have not been able to get tidal to log in since the update.
It’s a Windows 10 PC.
Hi @lightworkerpdx,
Can you send us your audirvana.log file at [email protected]?
to show AppData folder:
