Itunes library art not importing
Hi, folks. New user, everything fine but itunes art importing under “local”. Misses about half the art, where Itunes had 100%. Any quick tips that I might be missing? Any direction to look at? W11 but same problem under W10.
Thanks!
Hi @tsb,
Can you please take a look at the file themselves? Do you see a cover embed in it?
