I am using Audirvana to play High-Res files from a Windows-based NAS to my Naim ND5 XS2 through WiFi. Sometimes a track is ended abruptly (this happens in the last 20 to 30 seconds of the track) and there is a jump to the next track. This happens irregularly and with different files. Any idea what could be the reason and how it could be fixed?
Reducing the memory to 5000MB did not help. The error however only occurs with HighRes files, FLAC worked ok. Usually the first track of the playlist still finishes correctly. The jump happens in the last 30 seconds of the second or third track that is played.
Yes, it happens with all sample rates above 44.1 kHz at various bit rates (with and without DSD support). Jump to next track occurs at varying positions of the track played.
I think you might consider contacting Naim about it as your ND5XS2 seems to have an issue with his internal UPnP clocking since it sees the track as ended before the real end of it.
