Keep getting kicked out. "Sign in with your Audirvana ccount"
As of today this keeps happening on my Windows machine. I paly a few tracks and there’s a message about something “endpoint” and the request to sign in again. When I do, Audirvana won’t open up and I have to close the process in Task Manager before being able to open Audirvana again. At which point he askes me again to log in and the same thing happens.
I haven’t changed anything but maybe some silent update got in, I don’t know. I’m attaching a debug log:
Audirvana Origin 2.5.19 (20519)
Windows 11 (26100) x86_64 with 24GB physical RAM
Connected account of : Renato Morais
Available network interfaces:
Ethernet ({9c55c572-235f-4d2c-9cbc-d645f3aa42a2}) is PUBLIC
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Sync list: 2 folders
AUTO: D:\Utilizador\Music\Classic Music
AUTO: D:\Utilizador\Music\Music
Sort and display order: en
Library database path: C:\Users\morai\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2a01:11:8910:4c90:7b1:df1d:eb9b:ebe3 on port 63620
Font size: large
Language: English
My Music
Library
Startup view: Library: Artists
Number of paired remotes: 3
Screen saver disabled: no
Active method: UPnP
Ethernet
Preferred device: [UPnP] Motivo-UPnP/AV Model UID:Volumio Volumio Motivo UID:uuid:f60cec80-6f4f-e0b9-4543-d83addb1db34
Selected device:Motivo-UPnP/AV
Manufacturer: Volumio
Model name: Volumio Motivo
Model UID: Volumio Volumio Motivo
UID: uuid:f60cec80-6f4f-e0b9-4543-d83addb1db34
UPnP device at http://192.168.1.21:49152/uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/description.xml
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 32
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit little endian 705.6kHz finite length
2 ch Integer PCM 24bit little endian 705.6kHz finite length
2 ch Integer PCM 32bit little endian 705.6kHz finite length
2 ch Integer PCM 16bit little endian 768kHz finite length
2 ch Integer PCM 24bit little endian 768kHz finite length
2 ch Integer PCM 32bit little endian 768kHz finite length
NrTracks: 1
MediaDuration: 0:04:06
CurrentURI: http://192.168.1.20:49152/audirvana/audio_f_4.wav
CurrentURIMetadata:
dc:titleDrifting Along</dc:title>
dc:creatorJamiroquai</dc:creator>
upnp:artistJamiroquai</upnp:artist>
upnp:genreAcid Jazz</upnp:genre>
upnp:albumArtURIhttp://192.168.1.20:49152/audirvana/artwork_0_4.jpg</upnp:albumArtURI>
upnp:albumTravelling Without Moving</upnp:album>
upnp:originalTrackNumber7</upnp:originalTrackNumber>
nextURI: http://192.168.1.20:49152/audirvana/audio_f_5.wav
nextURIMetadata:
dc:titleTheme to the Mothership</dc:title>
dc:creatorReturn To Forever</dc:creator>
upnp:artistReturn To Forever</upnp:artist>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://192.168.1.20:49152/audirvana/artwork_1_5.jpg</upnp:albumArtURI>
upnp:albumHymn of the Seventh Galaxy</upnp:album>
upnp:originalTrackNumber4</upnp:originalTrackNumber>
PlayMedium: HDD
Current transport actions:
Next,Previous,Play,Stop,Seek
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 Motivo-UPnP/AV Volumio https://volumio.com/ Volumio Motivo Volumio Motivo Volumio Motivo https://shop.volumio.com/product/motivo upmpdcli version 1.5.8 libupnpp 0.20.2 image/png 64 64 32 /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/icon.png /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/presentation.html uuid:f60cec80-6f4f-e0b9-4543-d83addb1db34 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/evt-urn-schemas-upnp-org-service-ConnectionManager-1
UPnP devices found : 2
Device #0: Motivo-UPnP/AV
Location: http://192.168.1.21:49152/uuid-f60cec80-6f4f-e0b9-4543-d83addb1db34/description.xml
Device #1: LG webOS TV UM7000PLA
UID: uuid:7cd8c15c-f862-d14b-42e0-bd52306bb652
Manufacturer: LG Electronics.
Model name: LG TV
Max. memory for audio buffers: 12288MB
Device #0: Speaker/Headphone (D10)
Manufacturer: Microsoft
Model UID: USB\VID_152A&PID_8750&REV_0102&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{01e2da29-9d28-40aa-a9ab-c51c5d421bc7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x8750
Model name: D10
Device #1: LG TV (NVIDIA High Definition Audio)
Manufacturer: NVIDIA
Model UID: HDAUDIO\FUNC_01&VEN_10DE&DEV_0080&SUBSYS_103C8338&REV_1001
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{a0552b92-f673-491c-a5dc-48a1af6dc8fd}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Here’s the message. It pops up about once per hour. I uninstalled and reinstalled Audirvana but that made no difference.
Seems like I caught the community at a bad time, with the Christmas holidays and all. But it seems to be sorted, at least for now. For future reference this is a helpful thread:
Audirvana won’t open - Request to the endpoint timed out - My Audirvāna Account - Audirvana
In my case nothing worked until I restarted the router. Cheers!
