I am running the current version of Studio 2.2.2 on a Windows 11 Desktop.
I am now randomly getting noise (short burst/pop) at the end of tracks using Kernel streaming.
I have tried EXTREME and HIGH and it happens using both of these settings.
I do not have this issue using ASIO and WASAPI.
There was a lot of discussion here on this topic previously but I am only noticing it now on 2.2.2 not remembering it not being much of an issue for me previously.
I have the same problem when using Kernel but only for some change of track in a playlist.
I think it is playlist related for me as well.
Hi, try deactivate upsampling.
I have upsampling deactivated and problem persists.
on my side this seam to be related to the Upsampling but seam to be different. Thanks for trying.
Même problème !
Still getting this noise with Kernel Streaming and after further listening I can confirm that it happens not only on playlists but also playing individual albums as well. Weather my music files, Qobuz or Tidal it can occur. Upsampling appears to have no effect on this.
Seems to happen more on playlists and on “extreme” mode but happens on the other settings as well.
Antoine?
