Kernel Streaming won't output from headphones on Bootcamp
I have a lightning-fast Bootcamp Windows 10 installation and I’ve never run into any compatibility issues with it before now.
However, I’m having a problem with Audirvāna Origin (& Studio), where whenever I try to use Kernel Streaming with my headphones plugged in, the output only plays from my Mac speakers instead of outputting sound from the headphones.
The output device is definitely selected as “Apple Audio Device (Headphones)” but it still plays from the speakers anyway. I’ve tried changing the output device in Audirvāna and rebooting the program a bunch of times, but to no success.
My headphones are set as the default audio device on my computer, yet Kernel Streaming seems to default to my speakers and I don’t know how I can change it. I tried disabling the Speaker device on my computer, which made the headphones the only output device able to be selected in Audirvāna, but even then it still played through the speakers.
I don’t have an external DAC yet, but maybe when I get one it will fix the problem?
In the meantime, here is my debug info:
Details
Audirvana Origin 1.0.2 (10002)
Windows 10 (19044) with 8GB physical RAM
Connected account of : 11111
SW volume control: ON
AUTO: C:\Users\11111\Desktop\11111
Library database path: C:\Users\11111\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 10.0.0.4 on port 49762
Max. memory for audio buffers: 2544MB
Headphones (Apple Audio Device)
Model UID:PCI\VEN_106B&DEV_1803&SUBSYS_1885106B&REV_01
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{636ca00c-3c08-453b-9959-cc30d7acae49}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 48kHz
Active Sample Rate: 48kHz
Model Name: Unknown manufacturer
Model UID: PCI\VEN_106B&DEV_1803&SUBSYS_1885106B&REV_01
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{636ca00c-3c08-453b-9959-cc30d7acae49}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Kernel Streaming capable
1 available sample rates up to 48000Hz
Simple stereo device: No
Device #0: Speakers (Apple Audio Device) Manufacturer: Apple Inc. Model UID: PCI\VEN_106B&DEV_1803&SUBSYS_1885106B&REV_01 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{bbd4ff2a-7cc9-4d3e-bbbf-b04c8aeaa412}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
Device #1: Headphones (Apple Audio Device) Manufacturer: Apple Inc. Model UID: PCI\VEN_106B&DEV_1803&SUBSYS_1885106B&REV_01 UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{636ca00c-3c08-453b-9959-cc30d7acae49}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Unknown manufacturer
WASAPI sounds fantastic and plays perfectly fine, but I would like to give Kernel Streaming a shot, so I’m hoping someone can give some advice. Thanks!
