LA Convolver Multi wav
Hello
I use LA Convolver with a 2Channel Filter (accurate). works fine.
I like to use a 4 channel filter as crossover. This does not work.
LA Convolver is able to work with multi filters. up to 128.
Audirvana seams to work only with two channels.
I have a virtual Dante Software. In my configuration it shows 8 Output channels. Audirvana does not “see” these 8 channels. Only 2.
I can load a Multi.wav filter in LA Convolver. This works. For example it shows 4 output channels to choose from. But I only have two “banks” for this filter. need 4.
By the way. When you play a song. LA Converter pops up. here you can put in additional filters while playing. But it does not affect the output, still 2 channel playing.
You can also open a second LA Convolver in parallel. but also effects only stereo.
Can someone help?
Other playing software does support this. You simply put in the filter and it plays to multi channel outputs as defined in the filter.
many thanks
Hi @TimMayer2610,
