Hi, I am using the trial version of audirvana origin in Japan, and I am thinking of purchasing the official version, but I have found two problems.
One is that when playing a song from a stand alone, less than a second or so of the beginning is missing. I felt that this is a problem that other players do not have, where you have to press the back button all the way down to play the song from the beginning.
Another problem is that when playing live music, there are no pauses between songs, and the music plays one after another, but this is also not a good thing, as the end of the song is missing or the beginning is interrupted.
In my environment, all the music data is stored and played on the local PC, so it should not have the same problem as network playback, but I am experiencing the same kind of trouble.
I have searched the forums and found that gapless playback is often mentioned, but no concrete answers or suggestions for improvement have been provided, which makes me worry. I don’t think it is possible that it is technically impossible.
I think it might be a specification of the software, because it does not improve even if I set WASAPI, ASIO, or Kernel Streaming. Other playback software such as hqplayer and foobar2000 have no problem at all, so I don’t think there is a problem with my hardware environment.
Even Windows Media Player, which is already more than 20 years old, can playback normally, so I would like to purchase this software if you can improve it.
I am using Topping U90 USB Bridge.
Driver version is 5.45.
Audirvana Origin 1.0.6 (10006)
Windows 11 (22000) with 192GB physical RAM
(Xeon W-3175X / SR-3 DARK)
Connected account of : -
Bandwidth at 0dB = 99.5%
Phase = 66%
AUTO: G:\Users-\Music
Library database path: C:\Users-\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on - on port -
Max. memory for audio buffers: 87002MB
Local Audio Engine: ASIO ASIO 2 driver version 1325
Model UID:
UID:
Topping USB Audio Device
Manufacturer:
Model Name: Topping USB Audio Device
Model UID: Topping USB Audio Device
2822400
5644800
11289600
22579200
DSD capability: Raw DSD (MSB)
Device #0: Topping USB Audio Device Manufacturer: Model UID: Topping USB Audio Device UID: Topping USB Audio Device Model Name: Topping USB Audio Device
UPnP devices found : 1
Device #0RX-A3040 B66622 UID: uuid:5f9ec1b3-ed59-1900-4530-00a0deb66622 Location: http://192.168.100.11:8080/MediaRenderer/desc.xml
