Less resolution and detail than on my phone. What am I doing wrong?
I’ve been A/Bing Audirvana Studio on my PC (Lenovo Legion) vs my Samsung Galaxy S23+ and I find I’m getting lower resolution and detail on Audirvana than my phone. Scratching my head on why that is. I use Lorde’s Buzzcut Season as a test track as at the beginning the reverb of the piano notes can be clearly heard to bounce off a hard surface (or it sounds like that to me). On my phone it’s very clear but on my pc it isn’t there at all.
I use the same set up apart from the source. Same USB cables, same dac/amp and same headphone (Hifiman HE1000se). I even use iFi Silencer+ and I have a power conditioner so my PC should have a reasonably clean sound.
I tested on different upsampling modes and the outcome is the same.
What am I missing?
hi @Soundmeow,
Do you have Dolby Atmos enabled on your Galaxy s23+?
I do but it automatically switches off when I connect the phone as a source. At least that’s what it shows on the phone. The icon isn’t highlighted
Please paste your debug information report here so folks can help the best possible…
It is found here: Settings–> My Account–> Help–> Debug info
Connected account of : xxxxxxx
Available network interfaces:
clareben ({103d2c3d-49a3-44a3-a8da-7027d3f7a7e1}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
	VST3 plugin #0: C:\Program Files\Common Files\VST3\TDR Nova.vst3
		ClassID: 56535454643561746472206E6F766100
	VST3 plugin #1: None
	VST3 plugin #2: None
	VST3 plugin #3: None
r8brain with Power Of Two upsampling
Bandwidth = 99.011%
AUTO: D:\Music
Library database path: C:\Users\Ben\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Tracks with no MBID: 415
Listening on 192.168.101.6 on port 63160
TIDAL: Connected as PREMIUM
Font size: large
My Music
Radios
Podcasts
Streaming
Number of paired remotes: 0
Screen saver disabled: no
Max. memory for audio buffers: 11058MB
Local Audio Engine: WASAPI
Speakers (HIFIMAN-EF400)
Model UID:USB\VID_2FC6&PID_F824&REV_0201&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{2956443e-ff24-466c-b8d2-ad7fcc4dc804}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 32bits Integer, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Selected device:Speakers (HIFIMAN-EF400)
Manufacturer: Microsoft
Model name: HIFIMAN-EF400
Model UID: USB\VID_2FC6&PID_F824&REV_0201&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{2956443e-ff24-466c-b8d2-ad7fcc4dc804}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x2fc6
USB Product ID: 0xf824
Max volume alert: Disabled
Simple stereo device: No
Local devices found : 3
Device #0: Speakers (FxSound Audio Enhancer)
Manufacturer: FxSound
Model UID: Root\FXVAD
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{6bcf3d1c-daf8-4bee-a658-d6a0400dc198}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Unknown model
Device #1: Speakers (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: INTELAUDIO\FUNC_01&VEN_10EC&DEV_0287&SUBSYS_17AA3850&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{71acaca5-d8f3-467e-be11-58bb9ff30407}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Model name: Intel High Definition Audio
Device #2: Speakers (HIFIMAN-EF400)
This is an incomplete report… you have cut-off the computer OS and memory information… Please include the computer/OS/memory information.
Disable your plug-in and disable upsampling, so to get a proper baseline reference and then work from there… Reduce the playback pre-load memory allocation to 4GB… Also try using ASIO.
Here’s the debug report with the OS and memory info. Also disabled the plug-in, upsampling and reduced the memory allocation to around 4gb. I can’t use ASIO. Doesn’t seem to work on my PC. Kernel Streaming works sporadically. Might be a driver update issue but I don’t know which driver to update.
Audirvana Studio 2.9.0 (20900)
Windows 11 (22631) with 16GB physical RAM
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Public profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Bandwidth = 99.011%
AUTO: D:\Music
Tracks with no MBID: 435
Listening on 192.168.101.6 on port 58666
Font size: large
My Music
Radios
Podcasts
Streaming
Max. memory for audio buffers: 4134MB
Device: 2ch 24bits Integer, 6 bytes per frame 192kHz
Active Sample Rate: 192kHz
Kernel Streaming capable
Device #0: Speakers (HIFIMAN-EF400)
Device #1: Speakers (FxSound Audio Enhancer)
Device #2: Speakers (Realtek(R) Audio)
