Letters Not Appearing in Album View
Letters are not appearing in album view even though I have many many albums starting with the letter.
How can I get the letter to reappear in the list?
Hello @ldsimpson16
This happens on my screen when the window is not very tall. The less height of the Audirvana window the fewer letters appear on the right.
Phil
Hi Phillp,
Thanks for the reply, but that is not my issue.
It is in full screen mode with margin space at the bottom and still does not include the letter “C”.
Until a week ago, the letter D was not included. Not sure what the problem is
Thanks again
Hi @ldsimpson16
I’m not sure either.
Although I had reported this issue in an earlier post.
It seems to have righted itself in my system. Send a message to @Antoine to see if he has any ideas.
Phil
Hi @ldsimpson16,
We do not display all the letters of the alphabet, If you click on the B or the D, do you also see your albums with C?
Yes, I can see the C albums, but there is no C in the list of letters. If, I want to get to be routed to the C albums I have to scroll through all of the B albums, or if choose D, I have to scroll up through all of the C albums
Is there no solution to this problem?
I don’t understand why the program would be coded to included they symbol for / for just one album, but not include the letter C that has a hundred albums. Is this behavior really just hard coded into the program and there is no way around it on the users’ end?
Hi @ldsimpson16,
We decided not to display all the symbols all the time but to display them based on the size of the window. The bigger the window, the more symbols will be displayed.
In your case, I can already see you have a large window, but if you try to make it even bigger, do you see the C, T and O displayed?
