There are too many synchronized folders for the monitoring capabilities of the operating system. Please consider grouping the folders by adding the parent folder, whose children will also be automatically synced.
macOS 10.11.6 with 4096MB RAM
Could you share the Debug info?
SW volume control: ON
Sync list: 224 foldersACTIVE STREAMING SERVICES
Max. memory for audio buffers: 256MB
Music Streamer II
Model UID:Music Streamer II:4852:0003
UID:AppleUSBAudioEngine:www.hirestech.com 2012 REV 1.8:Music Streamer II:1a200000:1
Active Sample Rate: 96kHz
Sample rate limitation: 96kHz
Limit bitdepth to 24bit: ON
ID 0x5a Music Streamer II Manufacturer:www.hirestech.com 2012 REV 1.8
Model UID:Music Streamer II:4852:0003 UID:AppleUSBAudioEngine:www.hirestech.com 2012 REV 1.8:Music Streamer II:3a200000:1
5 available sample rates up to 96000Hz
32000
Stream ID 0x5b 2 channels starting at 1
15 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
20 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 32kHz
Local devices found : 3
Device #0: ID 0x47 Salida integrada Manufacturer: Apple Inc. Model UID: AppleHDA:48 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x5a Music Streamer II Manufacturer: www.hirestech.com 2012 REV 1.8 Model UID: Music Streamer II:4852:0003 UID: AppleUSBAudioEngine:www.hirestech.com 2012 REV 1.8:Music Streamer II:3a200000:1
Device #2: ID 0x2e Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Fixed in effect load the root folder and in it the other folders that contain the music files, in turn it will be automatically synchronized every time you add content
