Thanks for getting back so quickly, here is the information.
macOS 11.2.3 with 8192MB RAM
Registered to nik taylor
Sync list: 2 folders
AUTO: /Volumes/Public/Shared Music/HiRes
AUTO: /Volumes/Public/Shared Music/Music
Library database path: /Users/niktaylor/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 6104MB
Zeppelinmini
Model UID:Zeppelinmini:19B5:0003
UID:AppleUSBAudioEngine:Bowers & Wilkins:Zeppelinmini:304:1
ID 0x32 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:123 UID:AppleHDAEngineOutput:1B,0,1,1:0
7 available sample rates up to 192000Hz
32000
Stream ID 0x33 2 channels starting at 1
7 virtual formats:
21 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:123 UID: AppleHDAEngineOutput:1B,0,1,1:0
UPnP devices found : 1
Device #0: ID 0x0 TX-8130 UID: uuid:25b09c28-789c-28b9-c595-280978b971c8 Location: http://10.0.1.23:8888/upnp_descriptor_0
