The listing of libraries that usually appears on the left part of the Audirvana screen is missing and I cannot get it back. Therefore, I cannot scroll though the library or find playlists. Is there a toggle or something…?
Thanks in advance,
Rick
Thanks in advance,
Rick
Your panel is mostly collapse to the max, try to see the line separating it to the main window by dragging it the the right…
Thanks! it worked.
