Hello everybody,
I want to get Audirvana to rebuild the library. Is that possible and if so how.
It’s a little messy.
thanks
Hello everybody,
thanks
In case you don’t have a backup… you can redo your database…
If you have Playlists that are important export them first to desktop and save them in a folder…
when Audirvana is reset, you can re-import them back in one shot. sadly to this day, the folders
they were in if so, are not back, you have to do them again…
If you continu and trash the database, you will lose also the play count number of how many times
you played those songs… if important to you or not.
Go to Audirvana preferences panel and delete with - sign your music folder(s) there.
Close Audirvana.
Trash All the files in that folder (that is your database of music, back it up! or not).
Restart Mac. Restart Audirvana.
Add a music folder when asked or go to prefs again and add one with + sign.
LET IT SYNC, even better don’t try to adjust windows or edit files, even playing music
while it is not finished… you’ll see the progress bar going… Could be long the first time
depending on how large your library is, and Mac is fast or not…
go to sleep if it is too long.
Then when finished, close Audirvana, yes close it before playing a song…
That way you will have your database from scratch saved without crashing or bugs.
Then copy the .sqlite file to somewhere else in a folder as a backup for today.
Do this as often you can, if you do many edits in your library or add many CDs, that way
if a bug comes back, you’ll have an not so far library to put back in the same place without bugs.
When copied, reopen Audirvana, and play a song.
Hi there,
Thank you very much for your quick answer.
I found all the files. Was a little triggy. In any case, the library is now tidied up again. I still have to correct a few small things.
Thank you again. That answers my question.
