Hi, Damien3
My main Mac was broken.
Please reset my license.
Hi, Damien3
Hello @omtaro,
I have removed all your computers from the license database.
You can now activate up to two computers.
To install Audirvana on your computer, you can proceed as follows:
Hi Damien, I need to reset my licenses again. I had to reinstall windows on my server PC (updated my audiolunux partition and that wiped out my W10 partition!) Anyway would appreciate a license reset. Also, I’m having a problem getting sound using a temporary license. When I hit play the song curser at the bottom moves for about 4 seconds then goes back to zero, with no sound for those four seconds. Below is the debug info:
Audirvana 3.5.44
Per track: OFF
Sync list: 4 folders
AUTO: F:\Music II
AUTO: F:\Music\Music\Music
Manual: (OFFLINE) C:\Users\Brian\Music
Manual: (OFFLINE) E:\Music II
Library database path: C:\Users\audiolinux\Desktop\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Audio Renderer-92 Model UID:ABC-PCB Audio Renderer-92 UID:uuid:0280AD230315-Audio Renderer
UPnP device at http://10.0.0.92:49152/amr.xml
Audio Renderer-92 Manufacturer:ABC-PCB
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/mpeg3:
http-get::audio/mp3:
http-get::audio/x-aiff:
http-get::audio/aiff:
http-get::audio/aac:
http-get::audio/mp4:
http-get::audio/m4a:
http-get::audio/dsd
http-get::audio/dsf
http-get:*:audio/dff
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
2 ch DSD 8bit little endian in 8bit chunk 2822.4kHz
2 ch DSD 8bit little endian in 8bit chunk 5644.8kHz
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Stop InstanceID in A_ARG_TYPE_InstanceID Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition CurrentPlayMode string NORMAL REPEAT_ALL INTRO NORMAL RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined LastChange string RelativeTimePosition string CurrentTrackURI string CurrentTrackDuration string CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED vendor-defined CurrentMediaDuration string AbsoluteCounterPosition i4 RelativeCounterPosition i4 A_ARG_TYPE_InstanceID ui4 AVTransportURI string TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT CurrentTrackMetaData string NextAVTransportURI string PossibleRecordQualityModes string CurrentTrack ui4 0 4294967295 1 AbsoluteTimePosition string NextAVTransportURIMetaData string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED vendor-defined CurrentTransportActions string RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED PossiblePlaybackStorageMedia string AVTransportURIMetaData string NumberOfTracks ui4 0 4294967295 A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME ABS_COUNT REL_COUNT TRACK_NR CHANNEL_FREQ TAPE-INDEX FRAME A_ARG_TYPE_SeekTarget string PossibleRecordStorageMedia string TransportStatus string OK ERROR_OCCURRED vendor-defined TransportPlaySpeed string 1 vendor-definedCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 http://10.0.0.92:49152/ urn:schemas-upnp-org:device:MediaRenderer:1 Audio Renderer-92 ABC-PCB http://www.abc-pcb.ch MR-MOD MR-MOD 1.0 http://www.abc-pcb.ch 0280AD230315 uuid:0280AD230315-Audio Renderer 123456789 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl1 rcscpd.xml /upnp/control/RenderingControl /upnp/event/RenderingControl urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport1 avtscpd.xml /upnp/control/AVTransport /upnp/event/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager1 cmscpd.xml /upnp/control/ConnectionManager /upnp/event/ConnectionManager /index.htmlUPnP devices found : 2
Device #0Audio Renderer-92 UID: uuid:0280AD230315-Audio Renderer Location: http://10.0.0.92:49152/amr.xml
Device #1TSR-5790 D0BDC2 UID: uuid:9ab0c000-f668-11de-9976-00a0ded0bdc2 Location: http://10.0.0.143:49154/MediaRenderer/desc.xml
Max. memory for audio buffers: 31654MB
Local Audio Engine:WASAPI
Local devices found : 0
Hello @boleary,
Thank you. All is working after changing audirvana security settings as you suggested. Hope you and yours are well.
Brian
Hello!
I’ve lost my license key. Can you resend the key to my email(same as registered here) please?
Vitalii
Requesting a license reset for Jeff Boggess (original purchase 62051966. Thanks you.
