Linux Install - Radio Won't Work
New user trying out Audirvana with my Naim NDS.
After a few initial problems my local files and Qobuz content play fine with no major issues. However, I cant get any of the radio stations to work. It will try to play for a second and then stops followed occasionally be a distorted sound. The radio station stays on the mini-player screen but there’s no sound.
Anyone else experience this problem?
@Antoine
I have created a session log if you would like me to send it to you?
Hi @Hogkite,
Can you please tell me the radio you tried to play?
Thx @Antoine ……here is the debug out
Radio stations tried:
BBC Radio2
JB Radio2
Radio Paradise (Global Mix)
Tried at different bit rates also
Audirvāna Studio 2.9.4
Linux 5.15.0-126-generic x86_64 x86_64 with 15.5GB physical RAM
Connected account of : hog kite
Sync list: 9 folders
AUTO: /mnt/MusicNASCD/CD1
AUTO: /mnt/MusicNASCD/CD2
AUTO: /mnt/MusicNASCD/CD3
AUTO: /mnt/MusicNASCD/CD4
AUTO: /mnt/MusicNASCD/CD5
AUTO: /mnt/MusicNASCD/CD6
AUTO: /mnt/MusicNASHQ/
AUTO: /mnt/MusicNASLQ/
AUTO: /mnt/MusicNASMQ/
Library database path: /home/audirvana/.local/share/audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 936
Listening on on port 32971
Font size: regular
Language: English
Show album covers in tracks list: no
My Music
Streaming
Radios
Podcasts
Startup view: Local Library: Artists
Use media keys: no
Number of paired remotes: 2
Active method: UPnP
Preferred device: [UPnP] NDS-8BC0 Model UID:Naim Audio Ltd. NDS UID:uuid:5F9EC1B3-ED59-79BB-4530-0011F6A68BC0
Selected device:NDS-8BC0
Manufacturer: Naim Audio Ltd.
Model name: NDS
Model UID: Naim Audio Ltd. NDS
UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A68BC0
UPnP device at http://192.168.2.25:8080/description.xml
8 available sample rates up to 5644800Hz
5644800
Volume control: Yes
Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD128
Avoid RAW PCM streams: No
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/wav:*
http-get::audio/x-mpegurl:
http-get:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::application/x-mpegurl:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
2 ch Integer PCM 16bit big endian 96kHz
2 ch Integer PCM 16bit big endian 88.2kHz
2 ch Integer PCM 24bit big endian 44.1kHz
2 ch Integer PCM 24bit big endian 48kHz
2 ch Integer PCM 24bit big endian 96kHz
2 ch Integer PCM 24bit big endian 88.2kHz
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.2.45:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play,Next,Previous
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 NDS-8BC0 Naim Audio Ltd. http://www.naimaudio.com Naim NDS digital audio streamer NDS 20-015-0022 https://www.naimaudio.com/product/nds 0011F6A68BC0 uuid:5F9EC1B3-ED59-79BB-4530-0011F6A68BC0 123810928305556upc urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt http://192.168.2.25:80/index.asp urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:0011F6A68BC0
UPnP devices found : 1
Device #0: NDS-8BC0
Model name: NDS
Max. memory for audio buffers: 7922MB
Local Audio Engine: Linux ALSA library 1.2.6.1
Advanced Linux Sound Architecture Driver Version k5.15.0-126-generic.
Local devices found : 7
Device #0: HDA Intel HDMI - HDMI 0
Manufacturer:
Model UID: HDA Intel HDMI - HDMI 0
UID: HDA Intel HDMI at 0xf7c34000 irq 33 - HDMI 0
Model name: HDA Intel HDMI
Device #1: HDA Intel HDMI - HDMI 1
Manufacturer:
Model UID: HDA Intel HDMI - HDMI 1
UID: HDA Intel HDMI at 0xf7c34000 irq 33 - HDMI 1
Device #2: HDA Intel HDMI - HDMI 2
Manufacturer:
Model UID: HDA Intel HDMI - HDMI 2
UID: HDA Intel HDMI at 0xf7c34000 irq 33 - HDMI 2
Device #3: HDA Intel HDMI - HDMI 3
Manufacturer:
Model UID: HDA Intel HDMI - HDMI 3
UID: HDA Intel HDMI at 0xf7c34000 irq 33 - HDMI 3
Device #4: HDA Intel HDMI - HDMI 4
Manufacturer:
Model UID: HDA Intel HDMI - HDMI 4
UID: HDA Intel HDMI at 0xf7c34000 irq 33 - HDMI 4
Device #5: HDA Intel PCH - ALC1150 Analog
Manufacturer:
Model UID: HDA Intel PCH - ALC1150 Analog
UID: HDA Intel PCH at 0xf7c30000 irq 34 - ALC1150 Analog
Model name: HDA Intel PCH
Device #6: HDA Intel PCH - ALC1150 Digital
Manufacturer:
Model UID: HDA Intel PCH - ALC1150 Digital
UID: HDA Intel PCH at 0xf7c30000 irq 34 - ALC1150 Digital
Chromecast devices found : 1
Device #0: Den speaker
Model name: Chromecast Audio
hi @Hogkite,
Can you please go into your audio output settings in Audirvāna Studio and enable those options before trying again to reproduce your issue?
Hi @Antoine
Have made those changes to the settings and things seem to have improved for some stations but not others. So stations such Radio Paradise and JB Radio2 as well as FIP (France) seem to be working OK although I only played each for a couple of minutes.
Some of the other stations such as BBC Radio 2 and Linn Radio won’t play at all. When I try these stations it also cause the Audirvana app to deselect my “NDS” from the Audio settings and select “HDA Intel HDMI - HDMI 0” from the local interfaces on my Linux box (i’m guessing that’s just my default audio device). I noticed immediately before it does this the output device says “error: no device selected”.
Indeed the NDS disappears from the audio settings section completely and needs a power off/on to recover. I captured the debug information again when this happened and have pasted below.
As I have Chromecast Audio device on my network I tried the same radio stations via Chromecast and although again only playing for a couple of minutes all the stations seemed to work ok?
Thx
Audirvana Studio 2.9.4
Tracks with no MBID: 937
Listening on on port 40305
Font size: regular
Language: English
My Music
Streaming
Radios
Podcasts
Use media keys: no
[UPnP] NDS-8BC0
Selected device:HDA Intel HDMI - HDMI 0
Manufacturer:
Multichannel: 8 channels
Channel bitmap: Oxff, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
4 ch Integer PCM 16bit little endian 44.1kHz
4 ch Integer PCM 32bit little endian 44.1kHz
4 ch Integer PCM 16bit little endian 48kHz
4 ch Integer PCM 32bit little endian 48kHz
4 ch Integer PCM 16bit little endian 88.2kHz
4 ch Integer PCM 32bit little endian 88.2kHz
4 ch Integer PCM 16bit little endian 96kHz
4 ch Integer PCM 32bit little endian 96kHz
4 ch Integer PCM 16bit little endian 176.4kHz
4 ch Integer PCM 32bit little endian 176.4kHz
4 ch Integer PCM 16bit little endian 192kHz
4 ch Integer PCM 32bit little endian 192kHz
6 ch Integer PCM 16bit little endian 44.1kHz
6 ch Integer PCM 32bit little endian 44.1kHz
6 ch Integer PCM 16bit little endian 48kHz
6 ch Integer PCM 32bit little endian 48kHz
6 ch Integer PCM 16bit little endian 88.2kHz
6 ch Integer PCM 32bit little endian 88.2kHz
6 ch Integer PCM 16bit little endian 96kHz
6 ch Integer PCM 32bit little endian 96kHz
6 ch Integer PCM 16bit little endian 176.4kHz
6 ch Integer PCM 32bit little endian 176.4kHz
6 ch Integer PCM 16bit little endian 192kHz
6 ch Integer PCM 32bit little endian 192kHz
8 ch Integer PCM 16bit little endian 44.1kHz
8 ch Integer PCM 32bit little endian 44.1kHz
8 ch Integer PCM 16bit little endian 48kHz
8 ch Integer PCM 32bit little endian 48kHz
8 ch Integer PCM 16bit little endian 88.2kHz
8 ch Integer PCM 32bit little endian 88.2kHz
8 ch Integer PCM 16bit little endian 96kHz
8 ch Integer PCM 32bit little endian 96kHz
8 ch Integer PCM 16bit little endian 176.4kHz
8 ch Integer PCM 32bit little endian 176.4kHz
8 ch Integer PCM 16bit little endian 192kHz
8 ch Integer PCM 32bit little endian 192kHz
Manufacturer:
Manufacturer:
Manufacturer:
Manufacturer:
Manufacturer:
Manufacturer:
Manufacturer:
Hi @Hogkite,
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send me the audirvana_studio.log file you can find by clicking the 'Open Log Folder’ button and send it at [email protected]?
Hi @Antoine
Log file sent by email
