Logging into Tidal
Hello. When starting Audirvan on Windows 11, the following message is displayed: Error loging to Todal. Cant get quality. When you try to log in to Tidal with the Connect button, the window to provide login data is not displayed
HI ,
I have exactly the same problem,. I get the same message. I use Win 10 and have the latest version of Audirvana Studio.
The same message and problem comes up when logging in on my Mac. Thanks
Hi. Can my problem be solved? I still can’t use Tidal in Audirvana.
I will just add that the problem appeared after the end of my Tidal subscription. I cannot enter a new user and password.
Ditto. Does anyone have a solution to this?
I have the same problem when registering. My credentials work in the browser, but not in Audirvana Studio.
Hello @Rhatalo @Karsten_L @phibimi and @JessieSD , are you using the latest version of Audirvāna Studio when you have this issue?
Yes, I have the latest version of Audirvana. The good news is that Tidal has taken action. I can login to Tidal in Audirvana
I have installed the latest version on a Mac. I can log into Tidal anywhere except in Audirvana and the Tidal desktop app.
Have you tried to reset your password?
Yes, I am using the latest version on both my PC and Mac. As with the others, I can access Tidal via their app and on all my devices, except via Audirvana. Thanks
Do you get an error when you try to log?
Today the Error message ‘Error logging to Tidal. Cant get quality’ does not appear and you can now see the Tidal albums on the AS dashboard. However, if you click a Tidal file, it will not play. It says 'Unable to Open … etc '. All Tidal files are the same way, Thanks
