I run a Mac mini late 2012
i5, 16gb ram, 500gb ssd and 120 gb ssd
its wired over lan and feeding my Gustard r26 via upnp.
in audivarna system optimizer is enabled.
irvana Studio 2.2.3 (20203)
macOS 10.15.7 with 16GB physical RAM
Connected account of : F
Per track: ONAu
Sync list: 0 folders
Library database path: /Users/Server/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49282
Active method: UPnP
Preferred device: [UPnP] Gustarender-1v4 Model UID:JF Light Industries UpMPD UID:uuid:f5b25574-985d-d945-d1cc-bee9d32375d0
Currently playing to UPnP device at 24 bits 48kHz
Selected device:Gustarender-1v4
Manufacturer: JF Light Industries
Model name: UpMPD
Model UID: JF Light Industries UpMPD
UID: uuid:f5b25574-985d-d945-d1cc-bee9d32375d0
UPnP device at http:/
ID 0x0
Volume control: Yes
DSD capability: Raw DSD (MSB)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: DSD512
Avoid RAW PCM streams: No
http-get::audio/l16:dlna.org_pn=lpcm
http-get::application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 11289.6kHz finite length
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz finite length
0 physical formats
UPnP devices found : 2
Device #0: ID 0x0 : [LG] webOS TV OLED55C9PLA
UID: uuid:f78c5892-46a8-49aa-3218-dad074f59c28
Manufacturer: LG Electronics.
Model name: LG TV
Device #1: ID 0x0 : Gustarender-1v4
Model name: UpMPD
Max. memory for audio buffers: 5142MB
Local Audio Engine: CoreAudio
Device #0: ID 0x33 Built-in Output
Model UID: AppleHDA:88
Chromecast devices found : 1
Device #0: SHIELD
Model name: SHIELD Android TV
