Lyngdorf MP60 2.1 not seeing Audirvana
Audirvana Studio 1.13.3 (11303)
macOS Version 12.4 (Build 21F79) with 8GB physical RAM
Connected account of : Charles Feathers
Replay Gain: by album
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Wed May 25 09:40:03 2022
Library database path: /Users/charlesfeathers/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49447
TIDAL: Connected as PREMIUM
Max. memory for audio buffers: 1480MB
Exclusive access: Disabled
LYNGDORF MP-60-7C7438
Model UID:Lyngdorf MP-60
UID:uuid:a42c46b5-3c02-4945-bf51-88eeeaee110a
ID 0x2c Mac mini Speakers
Model Name: Apple Inc. Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Stream ID 0x2d 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x2c Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
I don’t understand the problem exactly.
In your settings I see that Audirvana sees the Lyngdorf and identifies it as a DAC and also correctly identifies all the properties of your Lyngdorf. So you should be able to play music from Audirvana to your Lyngdorf. I see there are no UpnP devices detected, so I assume you have your Mac connected to the Lyngdorf with a USB connection?
Why do you want that the Lyngdorf sees Audirvana as well? There is no need for it. Or can’t you play music from Audirvana through the Lyngdorf? In that case have you checked on your Lyngdorf that it is set to the right input source?
Or am I missing something here?
Edit:
Sometimes I take posts too literally. I see now in posts below that it is solved :grinning:
Try to put exclusive access at ON
And Hog Mode at ON also and ser
Thanks, that brought back Lyngdorf as an output.
