I have a 2017 Mac mini, Teac 301 Dac, Tangent Ampster BT ll Amp. I’ll try to get to the point quickly. Hadn’t used the Mac Mini in over a year, it had stopped working and moved etc. Anyways put a new SSD drive in and got it going. Installed the Monterey 12.3 beta. Hooked up Dac to Mac Mini via USB downloaded Audirvāna software. Made the Teac USB my default device. Problem is I don’t have my sound. The Mac sound application says “The selected device has no output controls” Help me please this is getting very frustrating lol. Thanks
Can you paste the debug info here?
Audirvana Studio 1.11.0 (11100)
macOS Version 12.3 (Build 21E5222a) with 4GB physical RAM
Connected account of : Randy North
AUTO: /Volumes/Music HD/Music
Library database path: /Users/randynorth/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on fe80::4cd:6650:8d35:35d2%en1 on port 52129
Max. memory for audio buffers: 1024MB
Integer mode: Disabled
TEAC CORPORATION TEAC USB AUDIO DEVICE
Model UID:TEAC USB AUDIO DEVICE:0644:804A
UID:AppleUSBAudioEngine:TEAC Corporation:TEAC UD-301:001B0000716F8EB14E452865300E0027:1
ID 0x37 TEAC USB AUDIO DEVICE
Manufacturer: TEAC Corporation
Model Name: TEAC Corporation TEAC USB AUDIO DEVICE
Model UID: TEAC USB AUDIO DEVICE:0644:804A
UID: AppleUSBAudioEngine:TEAC Corporation:TEAC UD-301:001B0000716F8EB14E452865300E0027:1
8 available sample rates up to 352800Hz
32000
Stream ID 0x38 2 channels starting at 1
32 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
48 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
Local devices found : 3
Device #0: ID 0x2b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0 Model Name: Apple Inc. Built-in Output
Device #1: ID 0x32 HDMI Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutputDP:3,0,1,1:0:{6D1E-0001-01010101} Model Name: Apple Inc. HDMI
Device #2: ID 0x37 TEAC USB AUDIO DEVICE Manufacturer: TEAC Corporation Model UID: TEAC USB AUDIO DEVICE:0644:804A UID: AppleUSBAudioEngine:TEAC Corporation:TEAC UD-301:001B0000716F8EB14E452865300E0027:1 Model Name: TEAC Corporation TEAC USB AUDIO DEVICE
UPnP devices found : 2
Device #0: ID 0x0 YAS_209 UID: uuid:FFB8F002-25ED-01C4-2E14-4EB8FFB8F002 Location: http://192.168.0.4:49152/description.xml
Device #1: ID 0x0 [TV][LG]40UB8000-UB UID: uuid:9d8f6277-e206-94ea-5651-c9727549168a Location: http://192.168.0.9:1537/
Yes I believe it should be active, I just can’t figure out how to do it.
You tried that button ?
Do you have another computer with a bit more RAM.
Sorry I thought I replied to you earlier, I have been trying everything I can think of. I have a windows laptop but not another mac. I have it working with Catalina I think about a year and a half ago. When I put the new hard drive in a reinstalled with Catalina but let it upgrade to Monterey not thinking how it might effect things.
dont put your mac sound through your DAC, right click to tell mac speakers to be default… output and Alert, like in my pict
Studio will use the Midi Setup when it start, you don’t have to play with it yourself
Thanks I’ll give it a try tomorrow
That solution did not work, with the Dac not powered on the sound came through the Mac speakers.
Once I turned the Dac on the sound stopped, also I’m not sure how that would help anyways. The sound need to go through the Dac and my amplifier no ?
when you have the system macos sound on the dac, you can hear the trash bin getting empty while listening to music… you make an error on your mac, you hear the bump sound in your music… not ideal.
if your dac is seen in ,midi audio setup it is good. the rest is Studio that will take care of.
I just tried it with a different amp I had and it works now ! Thanks for all your help !
