MacBook as host - USB out to DAC
Let’s put it this way, can CD hold analog content?
Of course:
:wink:
A to D then D to A again? Storage device? Is this a trick question?
Y’all making my head hurt
And its lands and pits on cd……
Yeah that’s the ticket!
Sharks with friggin’ lasers. I just love the Austin Powers movies.
No match for sharks. And tornadoes. SHARKNADO.
Quality, Oscar-worthy entertainment mate :joy: :joy:
I like this stuff, have you seen Tremors?
It holds digital representations as ā€œbitsā€ and ā€œwordsā€ otherwise ā€œcodeā€ stored as lands and pits on a physical medium. Digital-audio is a binary encoding scheme protocol.
For those who have a ZEN DAC. I’ve looked up the colors that are being used when you are listening to certain types of stuff.
Yellow - PCM 44.1/48kHz
White - PCM 88.2 kHz - 384kHz
Cyan - DSD 64/128
Red - DSD 256
Green - MQA
Blue - MQA Studio
Magenta - MQB
Your going to make @Agoldnear jealous.
@sandsOfArrakis
Listening to an ISO from SACD.
How are the DAC lights.
I buy’s a M1 Mac Mini in full configuration (16GB RAM, 2TB SSD) in Aug. 2021, now with Ventura 13.0.1
My DAC - CORDA DACCORD ff runs fine over an ANKER 4 port USB Hub.
http://www.meier-audio.homepage.t-online.de/daccord.html
I have never heard fan noises, even in the summer when it was hot. I used a tool to turn up the fan, but it is still only audible very quietly.
Nice Greetings
Fritz (from Austria)
I am interested to buy a PCIe expansion chassis.
Can you recommend one?
Thank you
Matt
I recommend installing this Eifidelity AXF-107 power-filtering card (the link is for the AXF-107):
:sunglasses: :+1:
For connection between the Mac and the Sonnet you use the WW USB 3.1 cable?
Thanks again
Matt
I installed a super-quiet (noiseless) fan in my 2-slot Echo Express… :wink:
After a macOS update, I found the WW 3.1 cable was creating problems with hand-shaking to my DAC through my USB 3.0 path from the USB 3.0 card installed in my chassis, through iGalvanic, to my DAC… probably due to too many protocol transitions… So now I use a high-quality TB-3 cable with a little ferrite bead strategically installed at both ends of the cable… I wish WW would make a TB cable…
@Agoldnear
Did you try to get rid of USB and try a PCIe DAC card in the Sonnet like this one:
HDSPe AIO Pro - RME Audio Interfaces | Format Converters | Preamps | Network Audio & MADI Solutions (rme-audio.de)
Matt
No… I have a Focusrite Liquid Saffire 56 interface running on the Firewire bus … I’m using a Sonnettech USB 3.0 + Firewire 800 card on my headphone reference system… The USB transmission path is extremely quiet and very well clocked… I use the UpTone USB 2.0 card attached to the iGalvanic USB 2.0 output… I modulate all PCMxxx to DSD128 via r8Brain in Audirvana… The Eifidelity card is a great inexpensive investment in lowering the power-plane noise… I think it even helps clean-up the MBP bus controllers…
