Hello,
i know it is not released yet, but i just want to inform if some would like to try it
before its release date.
As for september 1, beta 6.
Audirvana Studio works the same for me as on Big Sur…
but i need more patience for some things…
First if i open my MacMini 2018 in the morning for the first time of the day, Studio don’t see my plugged USB DAC like on Big Sur. I simply have to remove the usb cable in the back of the Mac Mini and plug it in right after… If Audirvana Studio is already open, it will switch instantly to my DAC… no big deal, yet since i open it once a day…
It is the same for Audirvana 3.5.46 have to unplug the back of the Mini,
then replug it, ok too, if Audirvana is open.
For me it sounds as good or can’t see any difference with Big Sur to Monterey for sound quality…
The annoying thing is the library view. All is still good with 3.5.46 Thumbnails view.
Thumbnails View in Studio version, never works the first time…
you always have to click List view then re-click Thumbnails view… then you see them.
But if you want to go back, it is blank, you have to re-click List View then after Thumbnails view,
then it works again
Since Artists have only Thumbnails View, no List View, i can’t see nothing,
can’t use that mode: Artists view… just the view… they are there if you Search…
All Radios menus and Podcasts menus have only Thumbnails view…
so i cannot see any Radios or Podcasts and their submenus…
i don’t use them anyway
If i click one of my Playlists that are set to be seen in Thumbnails,
also i cannot see them first, have to click List View, then Thumbnails…
I have a bass little booster plugin Fabfilter pro Q3,
still works and both version with Monterey beta and
i don’t stream on any version, so i can’t say anything on that.
That’s about it… you were told…
