Missing artwork, options
Hi, I am on the Origin trial. When I set up initially, I noticed that maybe 50% ish of my albums had no artwork, including albums that had artwork in the folder already. So, I had some time today, and went through a lot of them manually, and most of them showed up in Audirvana (for Mac), just after downloading the artwork directly to the album folder in question. I also tried to do it via Audirvana, but it is painfully slow (up to 2 minutes for each one), for some reason, just adding a single, reasonably low bitrate jpeg from Discogs, and I have so many to do, that it would take too long to do.
I also noticed that when adding to the individual album folder directly, that sometimes Audirvana saw it immediately, and other times it would take a few minutes, and then in other cases, not at all, until I added them manually through Audirvana/edit metadata. Does Audirvana not grab album art and artist photos?
Is there any way to speed up this process? I have to do it all again for the artist photos, so hopefully there is a way?
Is there a way to stack, like in roon? If I look at my albums, where there is a double or triple CD rip, it shows it as 2 or 3 separate albums. It would be great if we could stack these, to tidy things up.
Finally, I am on an origin trial, but I think that the monthly Studio version may be a better fit, as I may add tidal back in later. Will I lose all the settings that I make, if I switch to Studio from origin? And does it work the same, as in the GUI side of things?
I’m running a MacBook Pro M3 Pro, 18GB RAM, and my music library is on an SSD SMB share, hung off the back of my Asus router. Sequoia 15.4. Audirvana for Max 2.5.21
Any help, much appreciated, thanks.
P.S I noticed that when Audirvana is open, even in the background, I have no control over the Macbook’s volume for anything until Audirvana is closed. Can this be changed? Thanks.
Welcome…
The Audirvāna Knowledge base…
So folks can provide insight into set-up, etc, please paste your debug information report in your post… It is found here:
Settings → My Account → Help → Debug info
One of Roon’s most useful features, unfortunately not present in Audirvana. You need to go to the first CD, select all the tracks, click on the meta data editor then, (after prior checking Artist/Album title is consistent across all 3 CD’s) edit the “disc# x out of x” boxes, exit the disc number box to activate save dialog button and click save. Repeat for all 3 CD’s and you should be good. (See screenshot)
I use a seperate metadata editor to do this as I find it more efficient and get more reliable results (on rare occasions).
Here you go. Thanks!
Audirvana Origin 2.5.21 (20522)
macOS Version 15.4 (Build 24E5206s) ARM64 with 18GB physical RAM
Connected account of : Me
Local network access: allowed
Sync list: 3 folders
Manual: (OFFLINE) /Volumes/Samsung_870_Evo_2TB/Albums
Manual: (OFFLINE) /Volumes/Samsung_870_Evo_2TB/Compilations
Manual: (OFFLINE) /Volumes/Samsung_870_Evo_2TB/My Mixes
Sort and display order: en
Library database path: /Users/edited/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 61145
Font size: regular
Library
My Music
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: no
Active method: UPnP
Wi-Fi
Preferred device: [UPnP] TDAI-1120-3225a8 Model UID:Lyngdorf TDAI-1120 UID:uuid:42015bbc-b499-47b6-8a9e-0ef8f949fef6
Selected device:TDAI-1120-3225a8
Manufacturer: Lyngdorf
Model name: TDAI-1120
Model UID: Lyngdorf TDAI-1120
UID: uuid:42015bbc-b499-47b6-8a9e-0ef8f949fef6
UPnP device at http://192.168.1.245:48297/42015bbc-b499-47b6-8a9e-0ef8f949fef6.xml
ID 0x0
Volume control: Yes
Not automatically detected, user set to MQA Decoder
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get:
:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:
:audio/mp4:DLNA.ORG_PN=HEAACv2_L2_320
http-get:
:audio/l16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/l16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
rtsp-rtp-udp:
:audio/mpeg:DLNA.ORG_PN=MP3
http-get::audio/vorbis:
http-get::audio/l16;rate=48000;channels=2:
http-get::audio/wave:
http-get::text/xml:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/x-m4a:
http-get::audio/x-wav:
http-get::audio/l16;rate=44100;channels=2:
http-get::audio/ogg:
http-get::audio/x-aac:
http-get::application/ogg:
http-get::audio/m4a:
http-get::audio/mpeg:
http-get::audio/wav:
http-get::audio/mp4:
http-get::audio/aiff:
http-get::audio/aac:
rtsp-rtp-udp::audio/l16;rate=48000;channels=1:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::text/xml:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/3gpp:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/l16;rate=44100;channels=1:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-aac:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/mpeg:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/aac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
Current transport actions:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 TDAI-1120-3225a8 Lyngdorf http://lyngdorf.com/ TDAI-1120 http://lyngdorf.com/tdai-1120/ 1950002267 uuid:42015bbc-b499-47b6-8a9e-0ef8f949fef6 image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.245/ DMR-1.51
UPnP devices found : 3
Device #0: ID 0x0 : TDAI-1120-3225a8
Location: http://192.168.1.245:48297/42015bbc-b499-47b6-8a9e-0ef8f949fef6.xml
Device #1: ID 0x0 : [LG] webOS TV UK6500PLA
UID: uuid:cf41d9e6-f201-4234-407b-013b41bf5b71
Manufacturer: LG Electronics.
Model name: LG TV
Device #2: ID 0x0 : 0000
UID: uuid:690b471a-1ba9-11eb-9621-7fc7713c25a4
Location: http://192.168.1.95:38400/MediaServer/rendererdevicedesc.xml
Manufacturer:
Model name: Renderer
Max. memory for audio buffers: 15360MB
Local Audio Engine: CoreAudio
Device #0: ID 0x49 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #1: ID 0x55 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Chromecast devices found : 2
Device #0: SHIELD
Model name: SHIELD Android TV
Device #1: TDAI-1120-3225a8
OK thanks for the reply, I’ll give it a try.
By the way, what metadata editor do you recommend for Mac? Thanks.
A free option is Musicbrainz Picard. A great Mac option, but a little bit unknown, is Amvedia Tag Editor. That’s a very powerful tool. Excel like interface for bulk editing, robust tag automation from different online databases. Customizable interface. It is very easy to start with, but it is more powerful once you educate yourself a bit.
I use Metadatics. It’s OK. Don’t have to use it for major metadata input as I purchase lossless/hires downloads from primarily Qobuz and occasionally NativeDSD or HD tracks. As such only have to correct sloppiness or inconsistency in purchased files.
Maybe someone who is a serial metadata editor can comment with the best editors they have used?
Hi again,
My trial was with Origin and finishes today, but I think I’m going to go with the monthly sub. do I need to uninstall origin and then install the other version, or does it detect what sub I have paid for? Also, will my artist photos backup work on the other version?
Thanks!
The billing is connected to your user account (your login) and not to the software installed.
