Mouse scrolling speed
Hi all,
My mouse scrolling speed is way too fast to navigate albums and playlists in a meaningful way. Can this be solved? I use a Windows 11 laptop.
Hello @panoptikon,
Thank you for your report. I also have this issue, are you using a mouse or your track pad when you have this behavior?
Hello!
I use the mousepad/trackpad.
I can reproduce the behavior but I would like to know the view you have the issue for playlist, can you send a screenshot of it?
Yes!
Only in a album? You said you also have this on playlist?
Anytime I scroll songs listed vertically - album or playlist. When I scroll the saved albums section, including their cover art, the issue is not there.
Are you a representative of the software?
Yes I am since I’m the customer support and partnership manager of Audirvāna :wink:
We had reports of this issue in the past but we have not been able to fix it for the moment.
OK! :slight_smile:
Too bad though, it prevents me from navigating the software in a convenient way. Fingers crossed for an update soon!
/ Chris
