Hi, Had a few issues with my router, and my library was on an SSD plugged into the USB3 port on the back of the router. I have today, moved the SSD and plugged it into an old Mac, and all is working fine, I can access, edit, delete things with no issue. I fired up Audirvana, and it obviously started complaining that it couldn’t access the library, so I deleted the old paths, and the database files, reopened Audirvana, and it would not scan my 3 music folders. One of the folders, it would scan some of the music. The main folder with the majority of files, it did not scan anything.
I thought it might be a weird permissions thing, so I made a duplicate folder called Albums 2, transferred all the contents of the main folder called Albums, and then once the transfer was complete, I deleted the old Albums folder, and renamed the new Albums 2 folder back to Albums. Deleted the database files again, and tried to rescan, but it kind of flickers briefly that it is scanning and then nothing. No music in Audirvana at all.
Edit, it only seems to be the Albums folder that won’t scan, the other 2 folders are scanning fine and they are in the same directory as the folder that won’t scan.
I’m on a Mac for playback, and also a Mac for the SMB share.
Is there anything else I can do to get this working please?
Thanks.
