Hi
Just installed Studio for the first time. So far so good. Really like the layout and libraries and sounds good from my brief listen.
Apologies if this has previously been answered. I’m struggling with MQA from Tidal. According to the album it should be 192 however via USB they are down sampled to my dac as 96. Is this normal or is there something in the settings I need to change?
Thanks for any help you can give
