Looking for some help. I play multi channel audio 5.1 from my MacBook Pro, HDMI out into my AV amplifier. The audio will play fine for a few minutes and then I’ll start to hear clicks and pops, they sound like digital artifacts. I have no idea what is going on. J River doesn’t have this issue so I know there not the audio files. I’m wondering if there are settings that I’m missing to set or is this a bug in the software. Thanks!
Hi @joey138,
Multi-channel DSD has been unplayable with Audirvana for me on my former MacBook Pro and current MacBook Air since 3.5.13… I recently tried Studio and Origin on my MacBook Air and this same issue you’re having persists. I have only 8gb of RAM (on both machines) and I have a sense that the overhead with Multi-channel DoP in the way it’s implemented by Audirvana requires more than 8g of RAM can accommodate although I’ve never been able to test it with more. My MacBook Air has an M1 processor which was a huge increase in processing power over my 2011 Pro so I would think that it’s not a processing capacity issue but the behavior was exactly the same on both 8g RAM machines. Two channel DSD works fine.
Thanks for the response Antoine. Here you go.
Audirvana Studio 2.9.0 (20900)
macOS 11.7.10 with 16GB physical RAM
Connected account of : Joseph Roma
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 3 folders
AUTO: /Volumes/5.1 Music/5.1 Music
AUTO: /Volumes/5.1 Music/Hi-Res Music
Manual: (OFFLINE) /Volumes/Vinyl/Vinyl Archive
Library database path: /Users/joeromano/Documents/AudirvanaDatabase.sqlite
Tracks with no MBID: 13513
Listening on 127.0.0.1 on port 53131
Font size: large
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: yes
Max. memory for audio buffers: 3908MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Actual I/O buffer frame size: 4096
Apple Inc. HDMI
Model UID:AppleHDA:94
UID:AppleHDAEngineOutputDP:0,1,0,1,1:0:{EE11-0014-01010101}
Device: 8ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 32 bytes per frame 96kHz
Active Sample Rate: 96kHz
Hog Mode is on
Sample rate limitation: 96kHz
Selected device:HDMI
Model name: Apple Inc. HDMI
Model UID: AppleHDA:94
UID: AppleHDAEngineOutputDP:0,1,0,1,1:0:{EE11-0014-01010101}
ID 0xe8
7 available sample rates up to 192000Hz
32000
Audio buffer frame size : 27 to 4096 frames
Multichannel: 8 channels
Channel bitmap: Ox3f, layout:
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 unused
Channel 7 unused
Number of channels: 8
Simple stereo device: No
Number of active channels: 8, in 1 stream(s)
Channel #6 :Stream 0 channel 6
Channel #7 :Stream 0 channel 7
Stream ID 0xe9 8 channels starting at 1
10 virtual formats:
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 192kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 176.4kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 96kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 88.2kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
8 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
24 physical formats
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned high in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 192kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 176.4kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 96kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 88.2kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 48kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 44.1kHz
8 ch Mixable linear PCM Interleaved 20 little endian Signed Integer aligned high in 32bit 32kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
8 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Local devices found : 7
Device #0: ID 0xd4 Built-in Output
Device #1: ID 0xe8 HDMI
Device #2: ID 0xde DENAFRIPS USB v3.12 | E1.3
Manufacturer: DENAFRIPS
Model UID: DENAFRIPS USB v3.12 | E1.3:152A:86EF
UID: AppleUSBAudioEngine:DENAFRIPS:DENAFRIPS USB v3.12 | E1.3:14210000:1
USB Vendor ID: 0x152a
USB Product ID: 0x86ef
Model name: DENAFRIPS USB v3.12 | E1.3
Device #3: ID 0xe4 Scarlett 2i2 USB
Manufacturer: Focusrite
Model UID: Scarlett 2i2 USB:1235:8210
UID: AppleUSBAudioEngine:Focusrite:Scarlett 2i2 USB:Y86CBFF1BCE7F3:1,2
USB Vendor ID: 0x1235
USB Product ID: 0x8210
Model name: Focusrite Scarlett 2i2 USB
Device #4: ID 0x3b Soundflower (2ch)
Manufacturer: ma++ ingalls for Cycling '74
Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower
UID: SoundflowerEngine:0
Model name: ma++ ingalls for Cycling '74 Soundflower (2ch)
Device #5: ID 0x46 Soundflower (64ch)
UID: SoundflowerEngine:1
Model name: ma++ ingalls for Cycling '74 Soundflower (64ch)
Device #6: ID 0x2e Aggregate Device
Model UID: ~:AMS2_Aggregate:0
Model name: Apple Inc. Aggregate Device
Apparently you are trying to playback via an Aggregate Device, which is going to be flaky… I don’t see that you have a homogenous multi-channel DAC…
The AU plug-in is not a surround EQ and unusable for multi-channel, it should be disabled… And SoundFlower is competing with Audirvana for Core Audio API’s… It appears to me that you need to find a more homogenous playback system configuration that reduces processing overhead with a true multi-channel DAC in this scenario.
