Multi device management
I noticed that most of the settings are not kept.
For each device, the following settings should be kept:
  • All setting in the DAC input panel, including exclusive access and integer mode
  • Volume control on/off and the level
  • Upsampling settings
Those two settings shoudl be actually saved by device in the actual version of the 2.0 beta.
In the case of UPnP, it works but int he case of local outputs it’s not. I will need to ask if it’s feasible or not.
It’s not working at the moment. DAC Input settings are not kept, I addition to that there’s the issue with the upsampling in the Mac version.
That would be a good thing to have also via USB. At least keep the setting whether software volume control is enabled or not.
Can you please share some screenshots? It’s working for me when I go from my IFi Device to my Mac speakers
Here is the first DAC, PCM only, integer mode on, sampling rate limit to 192KHz.
Changed to DSD capable DAC, DoP 1.1, MQA decoder, no sampling rate limit.
Changed to the first DAC, but the settings are not restored. The settings from the second DAC are kept.
Test with 2 external devices. Haven’t tested with the built in audio.
Can you send me a copy of the “Debug Info”?
Sure, here you go:
Audirvana Studio 1.99.15 (19915)
macOS 11.6.8 with 16GB physical RAM
Connected account of : [redacted]
Bandwidth at 0dB = 99.5%
Phase = 66%
Max allowed volume: 99.6355
AUTO: /Volumes/Music/
iTunes/Music library synchronization: last synchronized on Sat Mar 26 16:19:26 2022
Library database path: /Users/[redacted]/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 50208
Max. memory for audio buffers: 4086MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
HiBy R3PRO
Model UID:R3PRO:32BB:0004
UID:AppleUSBAudioEngine:HiBy:R3PRO:HiBy R3PRO:1
Hog Mode is on
Limit bitdepth to 24bit: ON
Selected device:R3PRO
Manufacturer: HiBy
Model name: HiBy R3PRO
Model UID: R3PRO:32BB:0004
UID: AppleUSBAudioEngine:HiBy:R3PRO:HiBy R3PRO:1
USB Vendor ID: 0x32bb
USB Product ID: 0x0004
ID 0x5e
32000
Stream ID 0x5f 2 channels starting at 1
36 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 384kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 32kHz
54 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer aligned low in 32bit 32kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 384kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 192kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 176.4kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 96kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 88.2kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 48kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 44.1kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer aligned low in 32bit 32kHz
Device #0: ID 0x3b Built-in Output
Model UID: AppleHDA:94
Device #1: ID 0x5e R3PRO
Manufacturer: HiBy
Chromecast devices found : 1
Device #0: Radiocast Bedroom
Model name: Chromecast Audio
What I notice now is that the debug info doesn’t correspond to the current settings in the DAC input panel:
You’ll notice that MQA is set to “MQA decoder” but the debug info shows “not MQA”. Also the sample rate limitation is set to “none”, while the debug info shows 192kHz. Same for DSD capability → Unhandled, while the interface shows DoP 1.1 and the DAC supports DSD256.
It’s the R3PRO you tried ? What is the other one?
Yes, the other one was CA DacMagic XS (dongle DAC).
Can you connect them together at the same time and send me again your debug info?
When I stopped the transport the interface caught up. Here is with both connected, still only keeps the last setting:
Phase = 66%
Integer mode: ON
HiBy R3PRO
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 176.4kHz
Active Sample Rate: 176.4kHz
Hog Mode is on
Manufacturer: HiBy
ID 0x5e
32000
36 virtual formats:
54 physical formats
Local devices found : 3
Device #1: ID 0x61 CA DacMagicXS 2.0
Manufacturer: CA
Model UID: CA DacMagicXS 2.0:22E8:DAC6
UID: AppleUSBAudioEngine:CA :CA DacMagicXS 2.0:14100000:1
USB Vendor ID: 0x22e8
USB Product ID: 0xdac6
Model name: CA DacMagicXS 2.0
Device #2: ID 0x5e R3PRO
Manufacturer: HiBy
With both devices connected I can’t play DSD at all. It gets converted to PCM. Settings appear to be mixed up.
Now I can’t even select DSD, the interface shows it as selected but it plays as PCM.
Phase = 66%
Listening on 127.0.0.1 on port 51811
Integer mode: ON
HiBy R3PRO
Hog Mode is on
Manufacturer: HiBy
ID 0x45
32000
Stream ID 0x46 2 channels starting at 1
36 virtual formats:
54 physical formats
Device #1: ID 0x45 R3PRO
Manufacturer: HiBy
There is obviously a discrepancy with what the interface shows and the internal setting. Debug info appears to be showing the current setting that AS uses, but I’m not able to change it. Tried restarting AS few times.
PM message sent.
Hello @bitracer,
Did you got the update we have done yesterday? We have made a fix for this issue.
There is still a problem when selecting a USB DAC. In the menu, it is impossible to switch directly from one DAC to another. It is necessary to select an Apple output first.
19:06:54.296864+0200 spindump Audirvana Studio 2.0 beta [82688]: slow hid response: not sampling due to conditions 0x8002
19:06:54.324795+0200 Audirvana Studio 2.0 beta AudioObjectAddPropertyListener: listener was already added
DSD r8brain oversampling is still displayed on the Mac output, which is impossible.
Finally, the DACs are no longer presented as handling DSD streams.
Capture d’écran 2022-09-24 à 19.18.35
