Multichannel UPnP playback in AO 2.6 and AS 2.11
AO 2.6 adds Multichannel UPnP playback … to compatible UPnP players… Question is what makes them compatible. I have been experimenting with my Oppo 205 and with Yamaha A3070. Neither of these work for DSD or PCM. I am not surprised for the Yamaha that I think does not really accept multichannel over UPnP, but I am puzzled with the Oppo 205 which does accept multichannel in both DSD and PCM over UPnP. I have been able to send over UPnP both through the Oppo app and LMS with the UPnP plugin. With AO 2.6, the music is sent as Stereo although I set the Oppo 205 settings in Audirvana to 6 channels… Anything I missed in settings?
Verify that your Oppo player is configured properly:
http://download.oppodigital.com/UDP20X/UDP-205_User_Manual_English_V1.0.0.pdf
Thanks. I did indeed check everything and as far as I can tell, it is all set correctly for multichannel music. I can play multichannel files into the Oppo, but not from Audirvana that sends stereo from my multichannel files, (whether dsf or flac)…
Do you know if you are actually playing the multi-channel file…? Did you rip those files yourself…?
If you are using macOS, check your speaker output configuration in Audio MIDI Setup
Please post your debug information report here so we can see your computer platform+Audirvāna synergies…
Hi @guardajoias,
Audirvana Origin 2.6.0 (20600)
macOS Version 15.5 (Build 24F74) ARM64 with 16GB physical RAM
Local network access: allowed
DSP ACTIVE in offline mode with plugins using new macOS API
No plugin active
Bandwidth at 0dB = 94.5953%
Filter max length = 23266
Anti-aliasing = 97.5873
Phase = 66%
Replay Gain: by album
Sync list: 3 folders
AUTO: /Users/Music/MusicaJá
AUTO: /Users/Music/MusicaNew
AUTO: /Volumes/music/Musica Multicanale
Sync folders at startup: NO
Sort and display order: en
Library database path: /Users/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 62916
Font size: large
My Music
Library
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 2
Screen saver disabled: no
Active method: UPnP
Wi-Fi
Preferred device: [UPnP] OPPO UDP-205 Model UID:OPPO OPPO UDP-205 UID:uuid:d7b96180-1dd1-11b2-9491-e2609a572ee1
Selected device:OPPO UDP-205
Manufacturer: OPPO
Model name: OPPO UDP-205
Model UID: OPPO OPPO UDP-205
UID: uuid:d7b96180-1dd1-11b2-9491-e2609a572ee1
UPnP device at http://10.110.40.62:49152/dmr_oppo.xml
ID 0x0
Volume control: Yes
Raw DSD (msb)
Multichannel: 6 channels
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: Disabled
Number of channels: 6
Avoid RAW PCM streams: No
http-get:*:audio/L16:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3X
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/L16:
http-get::audio/L8:
http-get::audio/mp1:
http-get::audio/mp2:
http-get::audio/mpeg:
http-get::audio/basic:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/x-matroska:
http-get::audio/mid:
http-get::audio/x-ms-wax:
http-get::audio/wav:
http-get::audio/x-ms-wma:
http-get::audio/vnd.rn-realaudio:
http-get::audio/x-wav:
http-get::audio/x-flac:
http-get::audio/mp4:
http-get::audio/x-m4a:
http-get::audio/x-ms-wmv:
http-get::audio/x-ogg:
http-get::audio/dff:
http-get::audio/dsd:
http-get::audio/dsf:
http-get::audio/ogg:
http-get::application/ogg:
http-get::audio/midi:
http-get::audio/x-aac:
http-get::audio/aac:
http-get::audio/x-ac3:
http-get::audio/x-atrac3:
http-get::audio/x-dts:
http-get::audio/x-pn-realaudio:
http-get::audio/x-quicktime:
http-get::audio/dolby:
http-get::audio/adts:
http-get::audio/3gpp:
http-get::audio/sonyoma:
http-get::audio/mp3:
http-get::audio/mpeg3:
http-get::audio/wma:
http-get::audio/flac:
http-get::audio/audible:http-get::video/vnd.dlna.mpeg-tts:
http-get::video/mp4:
http-get::video/3gpp:
http-get::video/mp2p:
http-get::video/mpeg2:
http-get::video/QuickTime:
http-get::video/x-dv:
http-get::video/x-motion-jpeg:
http-get::video/x-nerodigital-ps:
http-get::video/mp1s:
http-get::video/tts:
http-get::video/x-msvideo:
http-get::video/divx:
http-get::video/xiid:
http-get::video/asf:
http-get::video/wmv:
http-get::video/x-matroska:
http-get::video/rtml:
http-get::video/x-ms-wmv:
http-get::video/x-ms-wmx:
http-get::video/x-ms-wm:
http-get::video/x-ms-asf:
http-get::video/x-ms-wvx:
http-get::video/x-ms-dvr:
http-get::video/avi:
http-get::video/mpeg:
http-get::video/vnd.rn-realvideo:
http-get:*:video/x-pn-realmedia:http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_JP_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_PS_NTSC
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_PS_PAL
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO_ISO
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T
http-get:*:application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_ISO
http-get::image/vnd.ms-photo:
http-get::image/gif:
http-get::image/x-ycbcr-yuv420:
http-get::image/jpeg:
http-get::image/png:
http-get::image/mpo:
http-get::image/x-icon:
http-get::image/x-quicktime:
http-get::image/jpe:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
26 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 44.1kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 88.2kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 88.2kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 176.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 176.4kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 48kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 96kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 96kHz finite length
6 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 192kHz finite length
6 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 192kHz finite length
0 physical formats
Current transport actions:
<?xml version="1.0"?>
1
0
dlna:X_DLNADOCDMR-1.50</dlna:X_DLNADOC>
OPPO UDP-205
OPPO
qq:X_QPlay_SoftwareCapabilityQPlay:2.1</qq:X_QPlay_SoftwareCapability>
http://www.oppodigital.com/
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
control/RenderingControl
event/RenderingControl
/dmr_oppo_cms.xml
control/ConnectionManager
event/ConnectionManager
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
urn:schemas-tencent-com:service:QPlay:1
urn:tencent-com:serviceId:QPlay
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
UPnP devices found : 4
Device #0: ID 0x0 : Yamaha AV
UID: uuid:9ab0c000-f668-11de-9976-00a0defe3224
Location: http://10.110.40.61:49154/MediaRenderer/desc.xml
Manufacturer: Yamaha Corporation
Model name: RX-A3070
Device #1: ID 0x0 : SqueezeLite
UID: uuid:BCABE517-6056-2277-7803-6D3AEF33BBDB
Location: http://10.110.40.202:9000/plugins/UPnP/MediaRenderer.xml?player=7a%3Ac9%3A56%3A29%3Ad9%3A24
Manufacturer: Lyrion Community
Model name: Squeezebox
Device #2: ID 0x0 : My Devialet
UID: uuid:2eac44bc-0f26-42f2-b6fe-6aa6e375f6fc
Location: http://10.110.40.185:45497/2eac44bc-0f26-42f2-b6fe-6aa6e375f6fc.xml
Manufacturer: Devialet
Model name: Expert 220 Pro
Device #3: ID 0x0 : OPPO UDP-205
Manufacturer: OPPO
Max. memory for audio buffers: 6676MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Device #0: ID 0x5c MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Device #1: ID 0x33 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
Are you playing a multicannell track at the moment?
Not sure when I copied that yesterday. I will play a multichannel track and copy the debug info again later today and send it to you
Here is the debug info while playing the multichannel file:
No plugin active
Phase = 66%
Font size: large
My Music
Library
Active method: UPnP
Wi-Fi
Currently playing to UPnP device at 24 bits 176.4kHz
Manufacturer: OPPO
ID 0x0
Volume control: Yes
Raw DSD (msb)
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
http-get::audio/L8:
DLNA 1.5: Yes
Native Gapless playback: No
Number of active channels: 6, in 1 stream(s)
26 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:07:55.000
CurrentURI: http://10.110.40.202:49152/audirvana/audio_f_0.wav
CurrentURIMetadata:
dc:titleSymphony No. 9 in E flat major op. 70 Es-Dur: II Moderato</dc:title>
dc:creatorSHOSTAKOVICH Symphonies 9 and 10</dc:creator>
upnp:artistSHOSTAKOVICH Symphonies 9 and 10</upnp:artist>
upnp:genreClassical</upnp:genre>
upnp:albumArtURIhttp://10.110.40.202:49152/audirvana/artwork_0_0.jpg</upnp:albumArtURI>
upnp:albumSHOSTAKOVICH Symphonies 9 and 10</upnp:album>
nextURI: NOT_IMPLEMENTED
PlayMedium: NETWORK
RecordMedium: UNKNOWN
Play,Stop,Pause,Seek,X_DLNA_SeekTime
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
Device #2: ID 0x0 : Expert 220 Pro-9d03
Location: http://10.110.40.185:39715/2eac44bc-0f26-42f2-b6fe-6aa6e375f6fc.xml
Manufacturer: OPPO
Model UID: Speaker
Variation with DSD 64 enabled. But still only sending stereo (or L/R channels only) to the Oppo:
No plugin active
Phase = 66%
Font size: large
My Music
Library
Active method: UPnP
Wi-Fi
Currently playing to UPnP device at 24 bits 2822.4kHz
Manufacturer: OPPO
ID 0x0
7 available sample rates up to 2822400Hz
Volume control: Yes
Raw DSD (msb)
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
Maximum DSD rate set: DSD64
http-get::audio/L8:
DLNA 1.5: Yes
28 virtual formats:
6 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 2822.4kHz finite length
0 physical formats
CurrentTransportState: TRANSITIONING
NrTracks: 1
CurrentURI: http://10.110.40.202:49152/audirvana/audio_f_1.dff
CurrentURIMetadata:
upnp:albumArtURIhttp://10.110.40.202:49152/audirvana/artwork_0_1.jpg</upnp:albumArtURI>
PlayMedium: NETWORK
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
Manufacturer: OPPO
Model UID: Speaker
I appears that you are playing 24bit/176.4kHz PCM file rather than DSD because the up-sampling module is active and should not be active when playing 1-bit files… The DoP (DSD over PCM) carrier frequency for 2.8MHz DSD is 24/176.4kHz and it appears that the Oppo player does not support DoP playback… The player is looking for Raw DSD (msb)…
Try disabling up-sampling to see if you get the DSD multi-channel track…
Active method: UPnP
Wi-Fi
Manufacturer: OPPO
[/quote]
Volume control: Yes
Raw DSD (msb)
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
[/quote]
Yes, I have tried various combinations, including without upsampling (see below), without success so far…
No plugin active
Phase = 66%
Listening on on port 53886
Font size: large
My Music
Library
Active method: UPnP
Wi-Fi
Manufacturer: OPPO
ID 0x0
Volume control: Yes
Raw DSD (msb)
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
http-get::audio/L8:
DLNA 1.5: Yes
28 virtual formats:
0 physical formats
NrTracks: 1
CurrentURI: http://10.110.40.202:49152/audirvana/audio_f_0.dff
CurrentURIMetadata:
PlayMedium: NETWORK
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
1
0
OPPO UDP-205
OPPO
OPPO Media Renderer
OPPO UDP-205
20X
image/png
48
48
24
/icon/DMR-small.png
image/png
120
120
24
/icon/DMR-large.png
image/jpeg
48
48
24
/icon/DMR-small.jpg
image/jpeg
120
120
24
/icon/DMR-large.jpg
/dmr_oppo_rcs.xml
/dmr_oppo_cms.xml
/dmr_oppo_avts.xml
control/AVTransport
event/AVTransport
/control/Queue
/event/Queue
/dmr_oppo_queue.xml
UPnP devices found : 3
Device #1: ID 0x0 : Expert 220 Pro-9d03
Device #2: ID 0x0 : OPPO UDP-205
Manufacturer: OPPO
Model UID: Speaker
Device #1: ID 0x4a Microsoft Teams Audio
Can you please try with a PCM track instead for a test?
Is the speaker set-up in Audio MIDI Setup configured for 5.1 ?
This is PCM 176.4/24. Same results.
Connected account of : Marc Partridge
	No plugin active
Phase = 66%
AUTO: /Users/marcpartridge/Music/MusicaJá
AUTO: /Users/marcpartridge/Music/MusicaNew
Library database path: /Users/marcpartridge/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Font size: large
My Music
Library
Active method: UPnP
Wi-Fi
Manufacturer: OPPO
ID 0x0
Volume control: Yes
Raw DSD (msb)
Channel 2 unused
Channel 3 unused
Channel 4 unused
Channel 5 unused
http-get:
http-get:
http-get:
http-get:
http-get:
http-get::audio/mp4:DLNA.ORG_PN=HEAAC_L2_ISO
http-get:
http-get:
:audio/L16:*
http-get::audio/L8:
http-get::video/quicktime:
http-get::video/x-pn-realmedia:http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_JP_T
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_PS_PAL
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_NA_T
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/mpeg”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_NA_ISO
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_KO_T
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_HD_KO
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU
http-get:
http-get::application/x-dtcp1;CONTENTFORMAT=“video/vnd.dlna.mpeg-tts”:DLNA.ORG_PN=DTCP_MPEG_TS_SD_EU_T
http-get:
DLNA 1.5: Yes
28 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:05:23.000
CurrentURI: http://10.110.40.202:49152/audirvana/audio_f_1.wav
CurrentURIMetadata:
dc:titleSymphony n.5 in D minor op.47: II - Allegretto</dc:title>
dc:creatorShostakovich: Symphonies 5 & 6</dc:creator>
upnp:artistShostakovich: Symphonies 5 & 6</upnp:artist>
upnp:genre</upnp:genre>
upnp:albumShostakovich: Symphonies 5 & 6</upnp:album>
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 OPPO UDP-205 OPPO QPlay:2.1 http://www.oppodigital.com/ OPPO Media Renderer OPPO UDP-205 20X http://www.oppodigital.com/ uuid:d7b96180-1dd1-11b2-9491-e2609a572ee1 image/png 48 48 24 /icon/DMR-small.png image/png 120 120 24 /icon/DMR-large.png image/jpeg 48 48 24 /icon/DMR-small.jpg image/jpeg 120 120 24 /icon/DMR-large.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /dmr_oppo_rcs.xml control/RenderingControl event/RenderingControl urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /dmr_oppo_cms.xml control/ConnectionManager event/ConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /dmr_oppo_avts.xml control/AVTransport event/AVTransport urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /control/Queue /event/Queue /dmr_oppo_queue.xml
Manufacturer: OPPO
Model UID: Speaker
Hi Agoldnear. Not sure how Audio Midi setup would apply/be relevant to a UPnP connection? It sees my Mac speakers and can connect to Airplay devices, but it is only through Audirvana that I can connect to a UPnP device on the Mac… Happy to try something else…
The system needs to know how many audio streams it is sending to the output bus…
I see how that would apply to an USB or Airplay connection, but Audio Midi Setup does not see UPnP devices… Only Audirvana does…
The system needs to know there are more than two channels… Show a screenshot of your Speaker set-up in Audio MIDI Setup… It is packetizing the data with the appropriate headers…
