Music integrated mode doesn't display the right album info
When using music integrated mode albums should show on audirvana but it doesn’t. How to fix that? Mac OS Monterey 12.2.1
Do you mean local files or those you stream from Apple Music?
Those I stream from Apple Music
As far as I know that cannot be solved by Audirvana. Only if Apple makes the streamed files available to Audirvana through an API.
ok I understand
