In My new mac book pro 16 with Mac OS Catalina music playback does not start correctly by double clicking on the song but only using the “play” command, doing the double click I loose the first 5-6 seconds of every song. Moreover in the MUSIC integrate mode MUSIC becomes very slow and unresponsive to commands with a lot of latency… someone has experienced similar problems?
Hello @spigola, are you playing your music from the local library or streaming service? Can you run the maintenance option you can find in Audirvana settings in the “Maintenance” section?
I use only local library, I just run the maintenance options and all seems ok
Audirvana Mac Version 3.5.33 (3563)
macOS 10.15.3 with 16384MB RAM
Registered to Carlo Tonazzi
Sync list: 2 folders
Manual: (OFFLINE) /Volumes/LaCie/Music
AUTO: /Users/carlotonazzi/Desktop/musica
iTunes/Music library synchronization: last synchronized on Wed Feb 26 20:18:54 2020
Library database path: /Users/carlotonazzi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3396MB
Exclusive access: Disabled
Schiit Eitr
Model UID:Schiit Eitr:0D8C:0004
UID:AppleUSBAudioEngine:Schiit Audio:Schiit Eitr:14400000:1
Active Sample Rate: 48kHz
ID 0x4b Altoparlanti MacBook Pro Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x4c 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x4b Altoparlanti MacBook Pro Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
