Hopefully this is just me!
I can’t seem to find my Qobuz playlists in the remote app. I can see all the Qobuz created playlists etc but not the ones I have created in Qobuz itself. Could someone tell me where they should be please? Thx
Found Them!
Found Them!
For my side,
I have to select the Playlist tab and after that, select Quobuz tab on the top of the screen.
Yes, thanks I’d been searching around in the Qobuz section to no avail. But as you say a tab in the playlist section
Excuse me but I don’t understand if you found your playlists? If yes, can you mark the subject as resolved.
