My Tidal playlists on Audirvana
I don’t see my Tidal playlists on Audirvana, where can I find them?
MacOs High Sierra 10.13.6
Audirvana 3.5.50
Hi @DanieleRicciarelli,
If you are connected to your TIDAL account, you should see the playlists on the left panel of your software. If that’s not the case, please try to reconnect your TIDAL account.
