Thanks for the quick response, from your response - changing from Synology to QNAP seems not practical - meaning I would have to uproot my whole NAS setup for using Audirvana Origin.
This triggered me to have following idea / question - because my objective is to take out using Apple MacBook from running Audirvana legacy, I can have alternative of not using NAS, but use a Raspberry (require more setup and skill set to do so)
Raspberry (Runs Pi OS 64 bit) - install Audirvana Origin
Raspberry connect to my existing USB storage of music files
Question is - can I still use my itune song library directly by the Rspberry ?
or I need to do content migration to be usable by Rasp ?
Use Apple iPad running Audirvana Remote - connect to Rapsberry
If this is appropriate - can pursue this further with Origin
Hi @akdracom, you will need to migrate the iTunes file in the Rasp, and then you will be able to sync them directly by the Rasp once you have installed and started Audirvāna Origin on it.
“Migrate” means that I can use all my music files - .AIFF format (ripped from all my own CD’s using iTune / Apple Music) - by moving / copying them to Rasp’s storage - without having to go through the tedious ripping process.
