Navigation Letters missing
I miss the navigation letters (A,B,C…) in the remote App (IPAD) and on my MacMini (Audirvana Origin). Is this away or I just can’t find, because it I terrible to scroll down for any albums…
Hi @Viper1,
What are the sorting criterias you have?
Ciao Antoine
Thx for your fast reaction - I change the sort criteria from ‘speicherort’ to ‘album Künstler’ and the navigation letters appeared. so the problem is solved with your question :slight_smile:
Greets
I am missing W,X,Y,andZ in remote viewing albums. I have all A-Z when viewing artists
Long standing issue simply to do with Screen Size and ability to fit them in.
Are you using Audirvāna on a Mac, Windows, or Linux computer?
I froze a Mac on 10.11.6 El Capitan and am using it as a dedicated music server with Audirvana 3.5.50 and an external SSD. If I search by playlist it shows my playlists. Search by artist. and the full alphabet displays. Search by albums and only A-V appear. Not selecting a letter just scrolling to the end and my access stops at V. If I search for a W X Y or Z the music is still there but this becomes the only way I can access these titles in album mode.
