Hi All, while I install, I see below error message. can anyone help ?
Same problem here! Any solution?
@patrick - Can you update to the upcoming Audirvana 3.5 beta (currently 3.4.914) by getting it from: https://audirvana.com/delivery/windows/index.html
OK thanks Damien, I have been able to install Audirvana.
