Need help from my friend
Bonjour,
After many years of using Audirvana I just upgraded to studio, Whaou ! It’s a real gap in term of functionalities and then also sound, my respect to the creator !
Nevertheless there is one setting I missed:
. Sometimes, and often when using the remote, songs are changing every 30 seconds… Where can I change this ?
Thanks in advance
Have a nice Sunday
Laurent
It means you either play a song on a streaming service that you can buy, but not stream, or your login to the streaming service does not function. Log out and log in again to Qobuz or Tidal within Audirvana.
Thanks.
I found it…
I have two inscriptions at quobuz and one is free, Which was connected to the iPad and then limited in streaming…
Once i connected the other, it stopped…
