Audirvana 3.5.40
AUTO: \192.168.1.74\Syn_Volume 3\MultiChannel SACD_DSF n FLAC
Library database path: Y:\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Denon AVC-X4700H Model UID:Denon Denon AVC-X4700H UID:uuid:bbed7f53-1a42-115a-0080-00067839b2a6
UPnP device at http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Denon AVC-X4700H Manufacturer:Denon
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
2 ch Integer PCM 24bit little endian 352.8kHz
2 ch Integer PCM 24bit little endian 384kHz
NrTracks: 0
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Denon AVC-X4700H Denon http://www.denon.com Denon AVC-X4700H Aios 4.025 DBCT062002047 uuid:bbed7f53-1a42-115a-0080-00067839b2a6 00000002 1256 8080 urn:schemas-upnp-org:device:MediaRenderer:1 Denon AVC-X4700H Denon http://www.denon.com Denon AVC-X4700H Aios 4.025 uuid:1c02ff13-ac46-18a7-0080-00067839b2a6 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Denon http://www.denon.com Denon AVC-X4700H Aios 4.025 uuid:59df25e9-3420-1c56-0080-00067839b2a6 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Denon AVC-X4700H Denon http://www.denon.com Denon AVC-X4700H Aios 4.025 DBCT062002047 uuid:0177b5bf-1e29-b736-7c11-ba3b081abc96 AIOS:0001 161056 Thu 2020-07-23 00:50:21 1.562.281 00:06:78:39:B2:A4 en_EU 4 Aios 4.025 1 Production 00:06:78:39:B2:A6 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Denon AVC-X4700H Denon http://www.denon.com Shares User defined folders and files to other Universal Plug and Play media devices. Denon AVC-X4700H Aios 4.025 DBCT062002047 uuid:73ab6b66-53f4-a7bf-9888-268794d4c7e9 True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 9
Device #0rPlay-05d64a UID: uuid:3d62cbc4-32f8-4fbc-8618-001b7c070196 Location: http://192.168.1.76:49152/description.xml
Device #1Denon AVC-X4700H UID: uuid:bbed7f53-1a42-115a-0080-00067839b2a6 Location: http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Device #2Bose Master UID: uuid:968bda60-4637-ab91-3374-abf648c109e2 Location: http://192.168.1.204:8091/968bda60-4637-ab91-3374-abf648c109e2.xml
Device #3Denon AVC-X4700H UID: uuid:1c02ff13-ac46-18a7-0080-00067839b2a6 Location: http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Device #4Denon AVC-X4700H UID: uuid:59df25e9-3420-1c56-0080-00067839b2a6 Location: http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Device #5Denon AVC-X4700H UID: uuid:0177b5bf-1e29-b736-7c11-ba3b081abc96 Location: http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Device #6Denon AVC-X4700H UID: uuid:73ab6b66-53f4-a7bf-9888-268794d4c7e9 Location: http://192.168.1.92:60006/upnp/desc/aios_device/aios_device.xml
Device #7Living Room TV UID: uuid:23456789-1234-1010-8000-38184C30704D Location: http://192.168.1.60:52323/MediaRenderer.xml
Device #8UBP-X800M2 UID: uuid:00000000-0000-1010-8000-94db562e3c56 Location: http://192.168.1.27:52323/dmr.xml
Max. memory for audio buffers: 4620MB
Local Audio Engine:WASAPI
Device #0: DENON-AVR (3- Intel® Display Audio) Manufacturer: Model UID: DENON-AVR (3- Intel® Display Audio) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{7e1a2ce8-59eb-4d22-9516-0bba21c6d59c}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
