Netgear readyshare
Recently switched from a Windows 10 computer to Windows 11. The readyshare location was recognized by Audirvana on the old computer but not the new one. Readyshare USB file sharing is enabled on the computer and the location is recognized by Wiim pro and audacity but not Audirvana. Thanks
Hi @waves, Audirvana depends on Windows 11 to access network shares. So you need to make sure the you can see your music library in the Windows File Explorer, and once that works Audirvana will have no problem.
Thanks. I can see the USB contents that are plugged into the routers USB port in the network folder when I look under file explorer, but when I go to that location in Audirvana under the local tab and select the network folder the USB drive is not there.
Windows c an be funky with the names of network shares … double-check that you’ve got something like \servername\sharename
