Recently upgraded my Bifrost to Unison USB and now I have problems with audio. Audirvana recognizes the DAC and the DAC makes a clicking sound whenever I start or stop Audirvana. However, there is no sound. I got it to work once by restarting computer but now it’s not working again. Running latest Audirvana on latest MacOS. Any ideas?
Hello @music4me,
Here it is. Thanks!
macOS 10.15.6 with 16384MB RAM
Registered to *******
SW volume control: ON
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Thu Jul 9 21:55:38 2020
Library database path: /Users/*******/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 808MB
Schiit Bifrost Unison USB
Model UID:Schiit Bifrost Unison USB :30BE:1003
UID:AppleUSBAudioEngine:Schiit Audio:Schiit Bifrost Unison USB :14400000:1
Active Sample Rate: 192kHz
ID 0x3e Schiit Bifrost Unison USB Manufacturer:Schiit Audio
Model UID:Schiit Bifrost Unison USB :30BE:1003 UID:AppleUSBAudioEngine:Schiit Audio:Schiit Bifrost Unison USB :14400000:1
Stream ID 0x3f 2 channels starting at 1
24 virtual formats:
36 physical formats
Device #0: ID 0x2f Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:129 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3e Schiit Bifrost Unison USB Manufacturer: Schiit Audio Model UID: Schiit Bifrost Unison USB :30BE:1003 UID: AppleUSBAudioEngine:Schiit Audio:Schiit Bifrost Unison USB :14400000:1
UPnP devices found : 1
Device #0: ID 0x0 [TV] Samsung 6 Series (55) UID: uuid:8742991b-2c3d-45a9-84c4-56cc4c4efeef Location: http://*******/dmr
Thank you for the debug info, can you try to go in your audio output settings in Audirvana to deactivate Integer mode?
Shut off integer - no change
I deselected “mute during sample rate change” and have audio now (with integer mode on). Let’s see if it stays working…
That worked for me too!
