Hi Damien,
Here you go:
macOS 10.15.7 with 32768MB RAM
Registered to Gary Robinson
Per track: OFF
Replay Gain: by album
Sync list: 4 folders
AUTO: /Users/gjr/Music/Music1/AAC
AUTO: /Users/gjr/Music/Music1/ALAC(16bit)
AUTO: /Users/gjr/Music/Music1/FLAC(16bit)
AUTO: /Users/gjr/Music/Music1/FLAC(24bit)
Library database path: /Users/gjr/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15022MB
X-SPDIF 2
Model UID:X-SPDIF 2:20B1:2004
UID:AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14110000:1
ID 0x31 X-SPDIF 2 Manufacturer:Matrix Audio
Model UID:X-SPDIF 2:20B1:2004 UID:AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14110000:1
Stream ID 0x32 2 channels starting at 1
30 virtual formats:
40 physical formats
Device #0: ID 0x31 X-SPDIF 2 Manufacturer: Matrix Audio Model UID: X-SPDIF 2:20B1:2004 UID: AppleUSBAudioEngine:Matrix Audio:X-SPDIF 2:14110000:1
Device #1: ID 0x56 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
