Hello,
I have downloaded the free trial verion of Audirvana, when i want to start to play a song with it (on my desktop or with Qobuz) i hav e no sound at all.
The track is loaded but the song doesn’t start stay at 0:00.
I have a asio driver for my Lynx L22 and i have no issue with foobar the sound is OK.
Debug mode:
Audirvana 3.5.5
Replay Gain: by track
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\Alex\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3068MB
Local Audio Engine:ASIO 2 driver version 2
ASIO Lynx
Model UID:ASIO Lynx
UID:ASIO Lynx
ASIO Lynx Manufacturer:
Model UID:ASIO Lynx UID:ASIO Lynx
Multichannel: 16 channels
Channel 2 mapped to 2
Channel 3 mapped to 3
Channel 4 mapped to 4
Channel 5 mapped to 5
Channel 6 mapped to 6
Channel 7 mapped to 7
Channel 8 mapped to 8
Channel 9 mapped to 9
Channel 10 mapped to 10
Channel 11 mapped to 11
Channel 12 mapped to 12
Channel 13 mapped to 13
Channel 14 mapped to 14
Channel 15 mapped to 15
Number of channels: 16
Simple stereo device: No
16 ch Integer PCM 32bit little endian 44.1kHz
16 ch Integer PCM 32bit little endian 48kHz
16 ch Integer PCM 32bit little endian 88.2kHz
16 ch Integer PCM 32bit little endian 96kHz
16 ch Integer PCM 32bit little endian 176.4kHz
16 ch Integer PCM 32bit little endian 192kHz
Device #0: ASIO Lynx Manufacturer: Model UID: ASIO Lynx UID: ASIO Lynx
Could you help me please ?
Thank you Alex
