Noise at beginning or end of song
Seems like this was addressed a while back but I can’t find it now. Now I have the problem with 24 bit/ 44.1 files, a pop after a song or before the next one.
Help
thanks
Hi @ejames,
Audirvana Origin 2.5.17 (20517)
Windows 11 (22635) x86_64 with 64GB physical RAM
Connected account of : Eliott James
Available network interfaces:
ATT4Qf8YIP ({b4e52222-8927-415a-ae8f-76ea3155b64d}) is private
Windows Defender Firewall status for this instance of Audirvana Origin
Active profile types: all
Private profile:
Firewall: enabled
Inbound: allowed
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
AUTO: C:\Users\eliot\Music\Audirvana Playlist
Library database path: C:\Users\eliot\AppData\Local\Packages\Audirvana.Audirvana-d488-4ebf-b1c4-596e08349a6a_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 2600:1700:4300:da0:1b6c:855d:fb03:c655 on port 55276
Font size: regular
Language: English
My Music
Library
Number of paired remotes: 0
Screen saver disabled: yes
Max. memory for audio buffers: 32768MB
Speakers (TOPPING USB DAC)
Model UID:TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0104&KS
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{502d553f-bdf3-44c8-a937-8db5fb27585e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Selected device:Speakers (TOPPING USB DAC)
Manufacturer: Topping
Model name: E70 Velvet
Model UID: TUSBAUDIO_ENUM\VID_152A&PID_8750&REV_0104&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{502d553f-bdf3-44c8-a937-8db5fb27585e}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x152a
USB Product ID: 0x8750
Kernel Streaming capable
Simple stereo device: No
Device #0: Speakers (TOPPING USB DAC)
Device #1: Main Out 1/2 (3- Studio 24c)
Manufacturer: PreSonus
Model UID: TUSBAUDIO_ENUM\VID_194F&PID_0109&REV_0117&KS
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{8d77c12d-9762-4d52-8c11-01762bc13fa4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x194f
USB Product ID: 0x0109
Model name: Studio 24c
UPnP devices found : 2
Device #0: [TV] Samsung 6 Series (65)
UID: uuid:78be158f-45f1-4ffb-8fc4-f8e3f4b00b58
Manufacturer: Samsung Electronics
Model name: UN65KU6290
Device #1: ZiP Hopper(Living Room 1)
UID: uuid:482e8dac-7fad-11df-afb7-74182c5ecba2
Manufacturer: Echostar Technologies LLC
Model name: XiP813 Hopper
Chromecast devices found : 1
Device #0: Wireless Joey 4
Model name: Wireless Joey 4
Do you get this issue only when you use Kernel Streaming or also with WASAPI?
That’s it, it was on kernal. Switched and noise is gone.
thanks
